Sony DVP-FX730 Screen Replacement
  1. Sony DVP-FX730 Screen Replacement, Monitor: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony DVP-FX730 Screen Replacement, Monitor: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your hand to remove the small back cover by gently pulling upward.
  2. Sony DVP-FX730 Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a screwdriver, remove the two 12 mm pan head screws.
  3. Sony DVP-FX730 Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The screen should now detach from the primary device.
    • The wires, indicated with a blue box, will still connect the screen.
  4. Sony DVP-FX730 Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony DVP-FX730 Screen Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the wires attached to the white base using tweezers to pull them up.
  5. Sony DVP-FX730 Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony DVP-FX730 Screen Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Referring back to Step 8, do the same with the wires attached to the black base.
  6. Sony DVP-FX730 Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The screen should now be completely separated from the main device.
  7. Sony DVP-FX730 Screen Replacement, Screen: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four rubber feet and the screws beneath.
    • Remove the two exposed screws on the left side.
    • Pull back the cables until the screw is visible.
  8. Sony DVP-FX730 Screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the spudger, separate the top and bottom covers.
  9. Sony DVP-FX730 Screen Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Identify the gray back of the screen.
  10. Sony DVP-FX730 Screen Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screws.
  11. Sony DVP-FX730 Screen Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the metal plates.
  12. Sony DVP-FX730 Screen Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony DVP-FX730 Screen Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using spudger, push the lock clips to unlock the ribbon cable.
    • Using tweezers, pull the connector loose.
  13. Sony DVP-FX730 Screen Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony DVP-FX730 Screen Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place your hand on the front of the screen and push upwards.
Oliver Woolsoncroft
crwdns2935283:001/20/12crwdne2935283:0
81 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 11-21, Maness Winter 2012 crwdns2935289:0Cal Poly, Team 11-21, Maness Winter 2012crwdne2935289:0
CPSU-MANESS-W12S11G21
crwdns2942667:0crwdne2942667:0 2,884
