Sony DVP-FX730 Monitor Replacement
  1. Sony DVP-FX730 Monitor Replacement, Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the five exposed 7.9 mm screws using a Phillips screwdriver.
    • Punch through the warranty sticker with the spudger.
    • Remove the screw underneath with the Phillips screwdriver.
  2. Sony DVP-FX730 Monitor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the rubber feet using the spudger.
    • Remove the screws that were covered by the rubber feet.
  3. Sony DVP-FX730 Monitor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Hold on to the corners of the cover and gently lift the cover.
    • The tray is still connected to the base with wires.
  4. Sony DVP-FX730 Monitor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently remove the wires with tweezers by pulling up on the base they are attached to.
  5. Sony DVP-FX730 Monitor Replacement, Monitor: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony DVP-FX730 Monitor Replacement, Monitor: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your hand to remove the small back cover by gently pulling upward.
  6. Sony DVP-FX730 Monitor Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a screwdriver, remove the two 12 mm pan head screws.
  7. Sony DVP-FX730 Monitor Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The screen should now detach from the primary device.
    • The wires, indicated with a blue box, will still connect the screen.
  8. Sony DVP-FX730 Monitor Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony DVP-FX730 Monitor Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the wires attached to the white base using tweezers to pull them up.
  9. Sony DVP-FX730 Monitor Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony DVP-FX730 Monitor Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Referring back to Step 8, do the same with the wires attached to the black base.
  10. Sony DVP-FX730 Monitor Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The screen should now be completely separated from the main device.
Andrew Ward
crwdns2935283:001/20/12crwdne2935283:0
111 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 11-21, Maness Winter 2012 crwdns2935289:0Cal Poly, Team 11-21, Maness Winter 2012crwdne2935289:0
CPSU-MANESS-W12S11G21
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 3,168
