Sony DSC-RX100MA Screen Replacement
    1. Sony DSC-RX100MA Screen Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony DSC-RX100MA Screen Replacement, Back Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony DSC-RX100MA Screen Replacement, Back Cover: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove battery by sliding the tab to open the cover
    2. Sony DSC-RX100MA Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony DSC-RX100MA Screen Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony DSC-RX100MA Screen Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Using the screwdriver, remove all screws (black 2.5mm) from outermost layer of the assembly.
      • All screws in the camera can be removed with the PH 0 driver head.
    3. Sony DSC-RX100MA Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony DSC-RX100MA Screen Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony DSC-RX100MA Screen Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Also using the screwdriver, remove screws (black 1mm) underneath articulated LCD screen.
      • Remove the marked 2.5 mm screws with the screwdriver
    4. Sony DSC-RX100MA Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony DSC-RX100MA Screen Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using the plastic opening tools, carefully pry off the bottom plate.
      • Do not pull too hard as you may break the plastic casing.
    5. Sony DSC-RX100MA Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony DSC-RX100MA Screen Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony DSC-RX100MA Screen Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Using the same plastic opening tools, separate the screen and back assembly from the front portion of the camera
      • Once the back assembly is slightly detached, pull the media covers for the HDMI and Multimedia ports
    6. Sony DSC-RX100MA Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony DSC-RX100MA Screen Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the back cover
    1. Sony DSC-RX100MA Screen Replacement, Screen: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony DSC-RX100MA Screen Replacement, Screen: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony DSC-RX100MA Screen Replacement, Screen: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Move side panel to get access to screws
      • Remove two screws (black 2.5mm) with PH #0 screwdriver
    2. Sony DSC-RX100MA Screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony DSC-RX100MA Screen Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove back panel assembly while still keeping ribbon cable attached
      • Be very gentle and care not to tear the gold ribbon cable. This will be a common theme throughout these replacement guides.
    3. Sony DSC-RX100MA Screen Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony DSC-RX100MA Screen Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Carefully unplug ribbon connector to fully detach LCD screen assembly from camera
KC Egger
crwdns2935283:002/10/17crwdne2935283:0
315 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 21-1, Maness Winter 2017 crwdns2935289:0Cal Poly, Team 21-1, Maness Winter 2017crwdne2935289:0
CPSU-MANESS-W17S21G1
crwdns2947412:05crwdne2947412:0
Any idea where I can get a set or replacement screws? one came out of my LCD joint and I can’t find replacements anywhere online. I’ve even tried Ebay.
Alberto Lora - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Definately be careful with the gold ribbon cable, looked at mine funny and it just snapped in two.. waiting on a replacement now :(
Connor Quinn - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I’ve ripped 2 of these before - not fun! Still… cheap enough to buy but delivery took a couple of weeks.
I had a cracked screen so had to take this out to replace as well - problem i’ve had is that although i stuck it down really well (with 3M 1mm double-sided tape, it doesn’t hold great and so the screen has risen a bit and doesn’t sit flush.
Just in the process now of sticking it down again but with a touch of superglue as i need it to hold down a bit better - that should hopefully be me done then :)
Great guide by the way KC Egger - thanks for taking the time to put this together - it’s been a life saver for me!
Jamie Dunkley - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Where did you purchase your screen, I’ve been trying to find one from Sony parts dealers and can’t find it. Any links would be helpful, thanks.
Ian Cullen - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Probably a late reply but I got my screen from AliExpress, there are still a lot of them for sale and the sellers include a ribbon cable with the screen.
For these cameras the official screen protector is Sony PCK-LM15 Screen Protector
I think mine was damaged by sunscreen on my hands when using the camera over summer so putting a protective layer on top should help preserve the new screen.
Andrew Fox - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936751:024crwdne2936751:0 13
crwdns2936753:07crwdne2936753:0 42
crwdns2936753:030crwdne2936753:0 133
crwdns2942667:0crwdne2942667:0 7,217
