Sony DCR-DVD 108 Motherboard Replacement
  1. Sony DCR-DVD 108 Motherboard Replacement, Sony DCR-DVD 108 Case Disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove all the 4.3mm screws on the bottom using a J000 Phillips screwdriver. There should be seven screws (4 silver, 2 black).
  2. Sony DCR-DVD 108 Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 5mm #0 Phillips screws on the underside of the LCD tuck-a-way.
  3. Sony DCR-DVD 108 Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 2mm #0 Phillips screw behind the battery.
  4. Sony DCR-DVD 108 Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open the dvd cover and remove the 3 4.3mm phillips screws. Including ones in the corners that may be hidden.
  5. Sony DCR-DVD 108 Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony DCR-DVD 108 Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once all the screws are removed you can safely pry open the camera case using a spudger.
  6. Sony DCR-DVD 108 Motherboard Replacement, Motherboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony DCR-DVD 108 Motherboard Replacement, Motherboard: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove all ribbon connectors from the motherboard using tweezers. Simply grab each ribbon cable and pull straight out of the connector.
    • Be careful not to bend the ribbon cables.
    • There is a hidden wire on the bottom of the board that should also be removed.
  7. Sony DCR-DVD 108 Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony DCR-DVD 108 Motherboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony DCR-DVD 108 Motherboard Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove 3 brown copper screws. Each copper screw has a #0 Phillips head and is 2.8mm in length.
  8. Sony DCR-DVD 108 Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the motherboard up from the outside edges to remove.
In order to reassemble your device, follow these instructions in reverse order.
Elijah DeWolf
crwdns2935283:002/09/16crwdne2935283:0
616 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 7-6, Cheng Spring 2016 crwdns2935289:0USF Tampa, Team 7-6, Cheng Spring 2016crwdne2935289:0
USFT-CHENG-S16S7G6
crwdns2936753:030crwdne2936753:0 37
crwdns2942667:0crwdne2942667:0 911
