Sony DCR-DVD 108 Front and Back Lens Replacement
  1. Sony DCR-DVD 108 Front and Back Lens Replacement, Sony DCR-DVD 108 Case Disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove all the 4.3mm screws on the bottom using a J000 Phillips screwdriver. There should be seven screws (4 silver, 2 black).
  2. Sony DCR-DVD 108 Front and Back Lens Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 5mm #0 Phillips screws on the underside of the LCD tuck-a-way.
  3. Sony DCR-DVD 108 Front and Back Lens Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 2mm #0 Phillips screw behind the battery.
  4. Sony DCR-DVD 108 Front and Back Lens Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open the dvd cover and remove the 3 4.3mm phillips screws. Including ones in the corners that may be hidden.
  5. Sony DCR-DVD 108 Front and Back Lens Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony DCR-DVD 108 Front and Back Lens Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once all the screws are removed you can safely pry open the camera case using a spudger.
  6. Sony DCR-DVD 108 Front and Back Lens Replacement, Front and Back Lens: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Take the half of camera containing both lens components and turn front portion towards you.
    • Remove the four 4.3mm Phillips #0 screws pictured.
  7. Sony DCR-DVD 108 Front and Back Lens Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove front lens and inspect for "dirt," smudges. or scratches. Use discretion, if lens appears too damaged, replace part.
  8. Sony DCR-DVD 108 Front and Back Lens Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull lens housing to expose housing channel.
  9. Sony DCR-DVD 108 Front and Back Lens Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With the pointed end of a plastic spudger, press latch located on the side of rear lens housing.
  10. Sony DCR-DVD 108 Front and Back Lens Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony DCR-DVD 108 Front and Back Lens Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once loosened gently pull and remove lens housing. The lens should now be free to inspect and replace.
In order to reassemble your device, follow these instructions in reverse order.
Elijah DeWolf
crwdns2935283:002/09/16crwdne2935283:0
616 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 7-6, Cheng Spring 2016 crwdns2935289:0USF Tampa, Team 7-6, Cheng Spring 2016crwdne2935289:0
USFT-CHENG-S16S7G6
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 595
