Unscrew six screws holding the cover.
Disconnect the two ribbon cables connecting the monitor
Disconnect two ribbon cables connecting the lens and sensor.
Apply a bit of force on the front of the lenses until they pop up.
Now you can safely remove them.
Disconnect ribbon cable connecting the flash with the motherboard.
and remove the flash.
Lift these two pieces and slide the metal cover off.
crwdns2935219:0crwdne2935219:0
If you want to disassemble the lens check out this guide!
