Sony Cyber-shot DSC-W570 LCD Screen Replacement
crwdns2942287:0crwdne2942287:0This is a guide to replace dead pixels, cracked screens, and malfunctioning button terminals.
crwdns2944105:0crwdne2944105:0
Begin by facing the camera bottom side up to reveal the two 2.93 mm long screws
Remove these two screws using a Philips #00 screwdriver
Turn the camera sideways on its left side making sure the two 2.93 mm long screws are facing upwards
Remove the two 2.93 mm long screws using a Phillips #00 screwdriver
Turn the camera on its right side making sure it is facing upwards
Remove the last two 2.93 mm long screws using a Phillips #00 screwdriver
Face the device with the camera lens facing upwards
Gently pry off each corner of the cover to remove it
Once all corners are pried off, gently lift off the cover and place it on the side
Flip the device, making sure the screen is facing upwards
Use the plastic opening tool to gently pry all along the corners and sides of the camera.
Gently lift off the entire back cover and place it on the side
Taking off the previous cover will reveal the two cables connecting the LCD screen to the motherboard below the screen.
Remove the LCD screen from the side opposite the battery terminals.
Watch carefully for the two cords mentioned in the previous step. These will still be connected.
The side will flip up as shown in the next step.
Pull these two cords straight back to disconnect them from the respective housings.
Caution: The housing does not need to be moved or adjusted in any way. DO NOT pull the cords at an angle, it can destroy the cords and the housing. Pull Straight Back!
This is what the camera should look like after 2 cords and the screen have been removed.
The lens cord is being held to the side for a clearer view.
And the screen replacement how??
do I need glue?
