Sony Cyber-shot DSC-W230 Ribbon Cable Replacement
  1. Sony Cyber-shot DSC-W230 Ribbon Cable Replacement, Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Begin by placing the camera upside down and removing the three small center screws.
    • All screws are the same size and length and can be used interchangably.
  2. Sony Cyber-shot DSC-W230 Ribbon Cable Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Cyber-shot DSC-W230 Ribbon Cable Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the camera on its side (Counterclockwise). Remove the two small screws on either side of the silver panel.
    • Turn the camera 180 degrees onto its other side and remove the two small screws on either side of the silver panel.
  3. Sony Cyber-shot DSC-W230 Ribbon Cable Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Cyber-shot DSC-W230 Ribbon Cable Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Cyber-shot DSC-W230 Ribbon Cable Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the camera's tripod mount located on the bottom of the camera.
    • Carefully remove the camera's tripod mount and place it aside.
    • Be careful not to lose this piece.
    • Rotate the silver panel labeled 4x clockwise.
  4. Sony Cyber-shot DSC-W230 Ribbon Cable Replacement, Separating Camera and Display: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Cyber-shot DSC-W230 Ribbon Cable Replacement, Separating Camera and Display: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Align the camera so that the side with "4x Optical Zoom" is facing toward you.
    • Gently twist the bottom corner clockwise until you feel the side panel unlock.
    • Lift off the side panel and set aside.
  5. Sony Cyber-shot DSC-W230 Ribbon Cable Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Cyber-shot DSC-W230 Ribbon Cable Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Rotate the camera 180 degrees to face the side panel with the lanyard loop on it.
    • Gently lift the panel vertically until it lifts off
    • Take care to not lose the small rectangular portion on the bottom of the panel.
  6. Sony Cyber-shot DSC-W230 Ribbon Cable Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Cyber-shot DSC-W230 Ribbon Cable Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Cyber-shot DSC-W230 Ribbon Cable Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Position the camera so the bottom is facing up and the display away from the surface.
    • Gently pry the screen portion from the camera portion with your fingers or a plastic prybar.
    • Do not fully separate the two components! the screen is attached by two ribbon cables.
    • Lay the display flat to expose the circuit board and the display control ribbon cables.
  7. Sony Cyber-shot DSC-W230 Ribbon Cable Replacement, Ribbon Cable: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a flat head screw driver gently pry up on the tab securing the larger ribbon cable which connects the display screen and camera sensor / battery housing.
    • Remove the ribbon cable connecting the LCD display and camera sensor / battery housing.
    • Following the same procedure, uninstall the ribbon cable connecting the main camera controls to the camera sensor and battery housing
  8. Sony Cyber-shot DSC-W230 Ribbon Cable Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Cyber-shot DSC-W230 Ribbon Cable Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Cyber-shot DSC-W230 Ribbon Cable Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Now turn your attention to the camera sensor and battery housing. Identify the two connection points of the large ribbon cable.
    • Carefully place a flathead screwdriver under the left ribbon cable connection point and pull up to disconnect.
    • Repeat the previous step but this time carefully remove the right ribbon cable connection point.
    • After both sides of the ribbon cable have been disconnected it is ready to be replaced.
Alex
crwdns2935283:003/09/12crwdne2935283:0
190 crwdns2915208:0crwdne2915208:0
Clemson, Team 2-3, Benson Spring 2012 crwdns2935289:0Clemson, Team 2-3, Benson Spring 2012crwdne2935289:0
CLEM-BENSON-S12S2G3
crwdns2935297:011crwdne2935297:0
The locking meachanism on the Monitors ribbon cable is broken on my camera.
It pivots and locks the ribbon down to create a secure connection. However, because of the Brocken lock one side is not locked down therefore the Monitor turns off when tapped.
Is there a place that I could get a replacement for this lock?
much appreciated.
Brandon Dufala - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 3,385
