Sony Cyber-shot DSC-T1 LCD Replacement
  1. Sony Cyber-shot DSC-T1 LCD Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Cyber-shot DSC-T1 LCD Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the battery door at the bottom of the camera.
    • Press down on the door and slide it back. The door will pop open.
  2. Sony Cyber-shot DSC-T1 LCD Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery from the door that you opened in the previous step.
  3. Sony Cyber-shot DSC-T1 LCD Replacement, Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Cyber-shot DSC-T1 LCD Replacement, Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Cyber-shot DSC-T1 LCD Replacement, Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • There are two screws on the left and right sides of the camera, and two screws on the bottom.
    • Use a PH00 screwdriver and remove the six 2.9mm screws.
  4. Sony Cyber-shot DSC-T1 LCD Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Cyber-shot DSC-T1 LCD Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use hands to gently pry the front casing away from the camera.
  5. Sony Cyber-shot DSC-T1 LCD Replacement, CCD Sensor Module: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Cyber-shot DSC-T1 LCD Replacement, CCD Sensor Module: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the tip of a spudger to flip up the tab on the ZIF connector securing the motherboard ribbon cable.
    • The second picture shows what these tabs look like in their open positions.
  6. Sony Cyber-shot DSC-T1 LCD Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grasp the CCD Sensor Module and remove it.
  7. Sony Cyber-shot DSC-T1 LCD Replacement, Motherboard Assembly: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Cyber-shot DSC-T1 LCD Replacement, Motherboard Assembly: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to slide the white piece on the back of the back cover to the right.
    • This will dislodge the white piece, allowing you to remove it from the back cover.
  8. Sony Cyber-shot DSC-T1 LCD Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the ribbon cables from these two ZIF connectors.
  9. Sony Cyber-shot DSC-T1 LCD Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Cyber-shot DSC-T1 LCD Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the motherboard assembly up and rotate it so you can easily see where the internals connect to the back cover.
    • Remove the ZIF connectors from the clamp on the left end of the top piece.
    • The motherboard assembly is now separated from the back cover.
  10. Sony Cyber-shot DSC-T1 LCD Replacement, LCD: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Cyber-shot DSC-T1 LCD Replacement, LCD: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a PH00 screwdriver to remove the 2.9 mm phillips screw on the upper left side of the case.
  11. Sony Cyber-shot DSC-T1 LCD Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Cyber-shot DSC-T1 LCD Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the back frame from the LCD assembly.
    • Turn the LCD assembly over and gently pull the top bar off (which has the shutter and power buttons).
  12. Sony Cyber-shot DSC-T1 LCD Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the tape off that holds the LCD to the assembly.
iDeleted
crwdns2935283:007/07/10crwdne2935283:0
2 101 crwdns2915208:0crwdne2915208:0
crwdns2935297:039crwdne2935297:0
crwdns2942667:0crwdne2942667:0 4,700
