Sony Cyber-shot DSC-P9 Top Button Replacement
  1. Sony Cyber-shot DSC-P9 Top Button Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the battery latch down the side of the camera with your hands.
    • The latch will automatically pop open.
  2. Sony Cyber-shot DSC-P9 Top Button Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unlatch the clip over the battery.
    • The battery will partially pop out.
  3. Sony Cyber-shot DSC-P9 Top Button Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Cyber-shot DSC-P9 Top Button Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the battery from the camera.
  4. Sony Cyber-shot DSC-P9 Top Button Replacement, Outer Casing: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Cyber-shot DSC-P9 Top Button Replacement, Outer Casing: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 3.0mm Phillips #000 screws on the top of the camera with the phillips screwdriver.
    • Remove the additional four 3.0mm Phillips #000 screws on the bottom of the camera.
  5. Sony Cyber-shot DSC-P9 Top Button Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Cyber-shot DSC-P9 Top Button Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once the screws are removed, slowly remove the back casing from the rest of the camera.
  6. Sony Cyber-shot DSC-P9 Top Button Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Cyber-shot DSC-P9 Top Button Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Then, pull the front case away from the rest of the camera.
  7. Sony Cyber-shot DSC-P9 Top Button Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After the casing is removed, the camera should look as shown.
  8. Sony Cyber-shot DSC-P9 Top Button Replacement, Top Button: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 3.0mm Phillips #000 screw above the battery door on the side of the camera.
  9. Sony Cyber-shot DSC-P9 Top Button Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull off the pieces of casing located on either side of the top button of the camera.
    • Both of the two pieces should slide off very easily. Do not force them off.
  10. Sony Cyber-shot DSC-P9 Top Button Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the top button piece. You will need to detach a small blue ribbon cable before the button can be fully removed.
Andrew Forster
crwdns2935283:004/16/12crwdne2935283:0
12 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 17-25, Amido Spring 2012 crwdns2935289:0Cal Poly, Team 17-25, Amido Spring 2012crwdne2935289:0
CPSU-AMIDO-S12S17G25
crwdns2942667:0crwdne2942667:0 786
