Slide the battery latch down the side of the camera with your hands.
The latch will automatically pop open.
Unlatch the clip over the battery.
The battery will partially pop out.
Remove the four 3.0mm Phillips #000 screws on the top of the camera with the phillips screwdriver.
Remove the additional four 3.0mm Phillips #000 screws on the bottom of the camera.
Once the screws are removed, slowly remove the back casing from the rest of the camera.
Then, pull the front case away from the rest of the camera.
After the casing is removed, the camera should look as shown.
Remove the 3.0mm Phillips #000 screw above the battery door on the side of the camera.
Pull off the pieces of casing located on either side of the top button of the camera.
Remove the top button piece. You will need to detach a small blue ribbon cable before the button can be fully removed.
