Sony Cyber-shot DSC-P9 Motherboard Replacement
  1. Sony Cyber-shot DSC-P9 Motherboard Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the battery latch down the side of the camera with your hands.
    • The latch will automatically pop open.
  2. Sony Cyber-shot DSC-P9 Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unlatch the clip over the battery.
    • The battery will partially pop out.
  3. Sony Cyber-shot DSC-P9 Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Cyber-shot DSC-P9 Motherboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the battery from the camera.
  4. Sony Cyber-shot DSC-P9 Motherboard Replacement, Outer Casing: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Cyber-shot DSC-P9 Motherboard Replacement, Outer Casing: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 3.0mm Phillips #000 screws on the top of the camera with the phillips screwdriver.
    • Remove the additional four 3.0mm Phillips #000 screws on the bottom of the camera.
  5. Sony Cyber-shot DSC-P9 Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Cyber-shot DSC-P9 Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once the screws are removed, slowly remove the back casing from the rest of the camera.
  6. Sony Cyber-shot DSC-P9 Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Cyber-shot DSC-P9 Motherboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Then, pull the front case away from the rest of the camera.
  7. Sony Cyber-shot DSC-P9 Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After the casing is removed, the camera should look as shown.
  8. Sony Cyber-shot DSC-P9 Motherboard Replacement, Lens: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Cyber-shot DSC-P9 Motherboard Replacement, Lens: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Dislodge the round casing from the lens.
    • Pull it away from the rest of the camera.
  9. Sony Cyber-shot DSC-P9 Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the two 4.0mm Phillips #000 screws from the display.
  10. Sony Cyber-shot DSC-P9 Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the two ribbon cables out of their slots on the back circuit board.
  11. Sony Cyber-shot DSC-P9 Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 4.0mm Phillips #000 screws holding the back panel in place.
  12. Sony Cyber-shot DSC-P9 Motherboard Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Cyber-shot DSC-P9 Motherboard Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Cyber-shot DSC-P9 Motherboard Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Work the back panel out from under the small grey clip.
    • Slide the back panel off of the camera by dislodging it from the remaining clips.
    • Below is a flat, orange cable connecting the lens to the motherboard.
    • Be careful not to bend the back plate during this process.
  13. Sony Cyber-shot DSC-P9 Motherboard Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the camera over so that you can see the front of the lens.
    • Two connectors link the lens to the motherboard.
    • Gently bring the lens away from the camera.
  14. Sony Cyber-shot DSC-P9 Motherboard Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the flat end of the plastic spudger tool, flip up the black tabs on the connectors.
    • Be careful not to exert too much force, as the connectors are delicate.
  15. Sony Cyber-shot DSC-P9 Motherboard Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Cyber-shot DSC-P9 Motherboard Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Cyber-shot DSC-P9 Motherboard Replacement: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently pull out the cables and move the lens away from the rest of the camera.
    • You should now have two distinct, separate components.
  16. Sony Cyber-shot DSC-P9 Motherboard Replacement, Motherboard: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Cyber-shot DSC-P9 Motherboard Replacement, Motherboard: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Rotate the bottom panel upwards and pull away with your hand.
  17. Sony Cyber-shot DSC-P9 Motherboard Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the one 2.5mm Phillips #000 screw on the bottom corner of the motherboard.
  18. Sony Cyber-shot DSC-P9 Motherboard Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the black tab holding the top-left ribbon cable in place with the spudger tool.
    • Remove the ribbon cable with the spudger by carefully pulling the cable directly out of the slot.
    • Take care not to rip the ribbon cable when pulling it out.
  19. Sony Cyber-shot DSC-P9 Motherboard Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the black tab that locks the orange ribbon cable in place.
    • Remove the ribbon cable by gently pulling it out of the slot with the spudger.
    • Take care not to rip the ribbon cable when pulling it out, and be mindful of a second cable beneath the first.
  20. Sony Cyber-shot DSC-P9 Motherboard Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Cyber-shot DSC-P9 Motherboard Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the second ribbon cable below the first one by gently pulling it out of the slot with the spudger.
  21. Sony Cyber-shot DSC-P9 Motherboard Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Cyber-shot DSC-P9 Motherboard Replacement: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the ribbon cable to the right of the bottom two ribbon cables with the spudger.
  22. Sony Cyber-shot DSC-P9 Motherboard Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Cyber-shot DSC-P9 Motherboard Replacement: crwdns2935265:022crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the motherboard out of the slot on the side of the camera where the lens used to be attached.
  23. Sony Cyber-shot DSC-P9 Motherboard Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Cyber-shot DSC-P9 Motherboard Replacement: crwdns2935265:023crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Cyber-shot DSC-P9 Motherboard Replacement: crwdns2935265:023crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the motherboard away from the camera.
    • Detach the final ribbon cable connecting the motherboard to the rest of the camera.
  24. Sony Cyber-shot DSC-P9 Motherboard Replacement: crwdns2935265:024crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The motherboard should now be fully disconnected from the rest of the camera.
Robert Potter
crwdns2935283:004/10/12crwdne2935283:0
41 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 17-25, Amido Spring 2012 crwdns2935289:0Cal Poly, Team 17-25, Amido Spring 2012crwdne2935289:0
CPSU-AMIDO-S12S17G25
crwdns2942667:0crwdne2942667:0 1,408
