This is a step-by-step guide to disassembling and replacing the flash in the Sony Cyber-shot camera.
First locate the appropriate screws for detachment.
Remove the five screws shown using a Phillips #00 Screwdriver.
Using a spudger, carefully pry open the front casing.
Carefully separate the front casing from the camera body.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Using tweezers, gently pull the ribbon trace out of its housing found on the left side of the flash.
Using a spudger, pry the small latch between the lens and the flash open to release the flash.
Pull the flash away from the camera.
