Sony Cyber-shot DSC-HX90V Lens Replacement
  1. Sony Cyber-shot DSC-HX90V Lens Replacement, Button board: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Cyber-shot DSC-HX90V Lens Replacement, Button board: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the device so bottom of the camera is facing up .
    • Remove the five marked screws with a Phillips #000 screwdriver.
    • Insert the spudger where arrow marks to gently remove the lower panel.
  2. Sony Cyber-shot DSC-HX90V Lens Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the marked screw on the side of the camera with a Phillips #000 screwdriver.
  3. Sony Cyber-shot DSC-HX90V Lens Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the marked screw with a Phillips #000 screwdriver.
  4. Sony Cyber-shot DSC-HX90V Lens Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Orient the device so the lens is facing down.
    • Remove the two black M1.4 X 3.5 Phillips head screws using Phillips #000 screwdriver.
  5. Sony Cyber-shot DSC-HX90V Lens Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the black M1.4 X 3.5 Phillips head screw.
  6. Sony Cyber-shot DSC-HX90V Lens Replacement, Side cover: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the plastic opening tool with a prying motion to remove the side cover of the camera.
    • The cover should come off easily but you might hear light snapping or popping.
  7. Sony Cyber-shot DSC-HX90V Lens Replacement, LCD: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Cyber-shot DSC-HX90V Lens Replacement, LCD: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the small screw under the multi/USB cover.
    • Use the plastic opening tool to remove the button board.
  8. Sony Cyber-shot DSC-HX90V Lens Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Cyber-shot DSC-HX90V Lens Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the control board data cable with care. Permanent damage may occur to the control board if tools are used to disconnect the data cable. Use your fingers only.
    • Disconnect the control board data cable by wiggling carefully with your fingertips. Set the control board to the side once it is disconnected.
  9. Sony Cyber-shot DSC-HX90V Lens Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • LCD screen is very fragile. Handle with care. Do not use tools to remove the screen.
    • Lift the metal plate and LCD screen simultaneously until it is perpendicular to the camera.
  10. Sony Cyber-shot DSC-HX90V Lens Replacement, Motherboard: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Cyber-shot DSC-HX90V Lens Replacement, Motherboard: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the ribbon cable connecting LCD display to camera sensor and battery housing.
  11. Sony Cyber-shot DSC-HX90V Lens Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure all ribbon cables are unplugged and remove the motherboard.
    • Ribbon wires can be easily damaged.
  12. Sony Cyber-shot DSC-HX90V Lens Replacement, Lens: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Cyber-shot DSC-HX90V Lens Replacement, Lens: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Cyber-shot DSC-HX90V Lens Replacement, Lens: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Press on the lens with your finger.
    • Gently pull the lens container out of the camera.
    • Make sure all ribbon wires are unplugged.
crwdns2935229:08crwdne2935229:0
Marin Rusinov
crwdns2935283:002/02/17crwdne2935283:0
853 crwdns2915208:0crwdne2915208:0
crwdns2947412:05crwdne2947412:0
Aside from a few missed screws, very nicely done. And I suspect that if one didn’t realize the need to remove those screws, sh/e probably shouldn’t be attempting the job in the first place. :) (I noted the comments after completing lens removal.)
Leon - crwdns2934203:0crwdne2934203:0
Can you comment where/specifically the missing screws that were not listed can be found? Any other guides out there that are more comprehensive?
Eric C -
First at step 7
Dufour -
At step 8 remove two 2mm screws both lower sides of LCD
Dufour - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 34
crwdns2936753:030crwdne2936753:0 171
crwdns2942667:0crwdne2942667:0 12,894
