Sony Cyber-shot DSC-HX80 LCD Screen Replacement
Gordon Jones
crwdns2944107:0crwdnd2944107:0Gordon Jonescrwdnd2944107:0crwdnd2944107:0crwdnd2944107:04crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Ndz 28, 2024crwdne2944111:0
crwdns2931287:025crwdne2931287:0
crwdns2937803:0crwdne2937803:0
crwdns2942287:0crwdne2942287:0
In the event of a damaged LCD screen, the only option may be for you to replace it. The following guide will take you step by step through the process.
  • Spudger
    Spudger
  • iFixit Opening Tool
    iFixit Opening Tool
  • Phillips #000 Screwdriver
crwdns2944105:0crwdne2944105:0
  1. Sony Cyber-shot DSC-HX80 LCD Screen Replacement, LCD Screen: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before disassembling any part of the camera, turn off the power by pressing down on the ON/OFF button. The ON/OFF button is located on top of the camera.
  2. Sony Cyber-shot DSC-HX80 LCD Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open the compartment located at the bottom of the camera. Slide the LOCK/OPEN switch to the OPEN side. Locate the small blue tab on the side. Pull it in direction away from battery. Remove the battery and set it aside.
  3. Sony Cyber-shot DSC-HX80 LCD Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Cyber-shot DSC-HX80 LCD Screen Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip LCD screen upwards.
    • Use the PH000 Phillips head screwdriver to remove the two 0.3 mm Phillips black screws located on the sides of the LCD screen. Place screws on magnetic mat or plastic bag.
    To complete this repair, I need the connecting piece behind the LCD. Do you have that piece if not wjere can Iget it or canyou get it for
    Frank Mohammed - crwdns2934203:0crwdne2934203:0
    To complete this repair, I need the connecting piece behind the LCD. Do you have that piece if not wjere can Iget it or canyou get it for me
  4. Sony Cyber-shot DSC-HX80 LCD Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Cyber-shot DSC-HX80 LCD Screen Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the PH000 Phillips head screwdriver to remove the two additional 0.3 mm black Phillips screws located on the top edge of the LCD screen. Place screws on magnetic mat or plastic bag.
  5. Sony Cyber-shot DSC-HX80 LCD Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Cyber-shot DSC-HX80 LCD Screen Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Cyber-shot DSC-HX80 LCD Screen Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a nylon spudger to gently remove the damaged LCD screen off the camera.
    • Replace LCD screen with new one.
    What is the black paper/plastic like strip at the bottom connecting the flip up part?? Mine detached from my camera and now the screen is black. Is that fixable?
    Brittani - crwdns2934203:0crwdne2934203:0
    Whst is the name of the connecting ribbons piece at the back of the LCD. On my camera ..Sony hx 80, the end of that piece that connects it to the camera is broken. Do you have that part? If not, where can I get it..reply to….frango@rogers.com…I am in Canada. THANKS.
    2 more photos showing the removal of the cables and then their reattachment would earn the author points.
    Randy Post - crwdns2934203:0crwdne2934203:0
    I agree, this how-to is skipping the hard part. Just busted one of the ribbon cables 😔
    Mike Millis -
Gordon Jones
crwdns2935283:010/02/18crwdne2935283:0
1,081 crwdns2915208:0crwdne2915208:0
Sam Houston State, Team S11-G1, Blackburne Fall 2018 crwdns2935289:0Sam Houston State, Team S11-G1, Blackburne Fall 2018crwdne2935289:0
SHSU-BLACKBURNE-F18S11G1
crwdns2947412:07crwdne2947412:0
You should note that there is a small rectangular magnet (perhaps 8mm long and 2mm across) that has to be placed at the top of the LCD directly under the flash switch. Otherwise the LCD image will be upside down.
Dale Bjerning - crwdns2934203:0crwdne2934203:0
Hello could you show a picture of where exactly under the flash has to be the magnetite tangle. Thanks.
Wolfina -
Anyone know where I can find the cable from the screen to the camera?
Thorusofer Dragon Knight - crwdns2934203:0crwdne2934203:0
same question here! i repalced the lcd thinking that was the problem but the lcd is still black. the viewfinder works fine so i think i need to replace the cable that goes from the camera to the screen. any info?
Facundo V -
where can i find the screen other then threw sony
ninjadawn25 - crwdns2934203:0crwdne2934203:0
Im looking for lcd screen for sony dsc hx80 on back TX08D155HMOAAA. A9N9I523946
Kaz Balcerzak - crwdns2934203:0crwdne2934203:0
Looking for replacement lcd screen fo sony dsc hx80 screen # on back is. TXO8D155HMOAAA. A9N9I523946
crwdns2936753:07crwdne2936753:0 25
crwdns2936753:030crwdne2936753:0 72
crwdns2942667:0crwdne2942667:0 4,082
