Complete replacement of the outer case requires complete dissassembly of the camera. This is a good time to replace other components if needed.
Orient the device so the bottom is facing up, and the lens is facing you ("bottom view").
Remove these two black M1.4 X 3.5 Phillips head screws.
The third, unmarked screw does not need to be removed at this time.
Orient the device so the LCD is facing you, and the HDMI cover is facing up (left side view).
Remove these three black M1.4 X 3.5 Phillips head screws.
Orient the device with the Wifi/GPS logo facing up ("right view").
Use a prying motion and a plastic opening tool to pry the side panel up.
Slide the panel downwards carefully, as these clips can be easy to break.
After removing the panel, remove the two black M1.4 X 3.5 Phillips head screws.
Orient the device so that the LCD is facing you ("back view").
Use the plastic opening tool with a prying motion, going between the case and the LCD, from the middle of the LCD to the right of the device, undoing the claws retaining the back.
Unhook the small printed circuit board by gently pressing the board towards the top of the device and lifting up.
Using a plastic opening tool remove the black LCD retainer clip to the right of LCD.
Use the plastic opening tool to gently lift the LCD from the device
Using the plastic opening tool to lift the black retaining clip up to disengage the ribbon cable. Then gently pull the ribbon cable to remove.
Remove the black M1.4 X 3.5 Phillips head screw in upper right corner of the device.
Service manual for reference: Click to go to the service manual.
Reorient the camera so you are looking at the "top view".
Remove the black M1.4 X 3.5 Phillips head screw next to the ON/OFF button circled in red.
Orient the device so you are looking at the "bottom view".
Remove the black M1.4 X 3.5 Phillps head screw located next to the tripod attachment.
The connections (red squares) have small black retaining clips. Using a plastic opening tool, lift upward towards the cable to unlock.
The upper ribbon cable simply pulls loose.
Discharge the capacitor by connecting the resistor jig between the highlighted squares.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use tweezers to remove the speaker retaining clip. The retaining hooks locations are indicated, but not exact.
Remove the speaker by desoldering its wires.
From the top of the camera, Use a plastic opening tool between the flash and the case to remove the flash.
And here is the how the flash module should look after being removed.
This is a reference image: it is possible to further disassemble this module, and is not necessary.
Remove the black M1.4 X 3.5 Phillips head screw in upper right corner of device.
Remove the black M1.4 X 3.5 Phillips head screw just below the ON/OFF button circled in red.
Remove the black M1.4 X 3.5 Phillips head screw located next to the tripod attachment.
After detaching retaining clips, gently lift to disconnect the ribbon cables.
Remove the orange M1.4 X 3.5 Phillips head screw located near the bottom of the camera.
Lift up the motherboard.
Disconnect the ribbon cable on the bottom by gently pulling.
Remove these two silver M1.4 X 4.0 Philips head screws.
Using the plastic opening tool between the front edge of the camera and the top "control assembly", pry and unhook the claws roughly located in the red square.
can i follow the same instruction for SONY DSC HX 10V .as both looks identical . when i shake my camera sound comes as if some parts are loosen but when i switched on my camera and the lens comes out that sound goes off . should i care for it or not ?
Thank you! Useful instructions.
Step 5 - perhaps a little more accurate step would be to lift up the bottom of the panel and then slide the panel downward. (reinstall in reverse direction).
I am having trouble orienting the control wheel - I tried to seat the middle button so it clicks and then set down the wheel on top but that does not seem to work after putting the back cover on. I’ve reopened and tried many times. Any suggestions on how to orient or reinstall the control wheel.
