Sony Cyber-shot DSC-H200 Tripod Port Replacement
  1. Sony Cyber-shot DSC-H200 Tripod Port Replacement, LCD Screen: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Cyber-shot DSC-H200 Tripod Port Replacement, LCD Screen: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Cyber-shot DSC-H200 Tripod Port Replacement, LCD Screen: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a screwdriver, remove the five 6mm screws located on the back panel.
    • Using a screwdriver, remove the two 3mm screws located on the back panel.
  2. Sony Cyber-shot DSC-H200 Tripod Port Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a screwdriver, remove one 6mm screw on the front panel.
    • Using a screwdriver, remove two 3mm screws on the front panel.
  3. Sony Cyber-shot DSC-H200 Tripod Port Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open the SD Door, unscrew and remove the single 6mm screw closest to "PUSH IN/OUT" under the SD card slot.
  4. Sony Cyber-shot DSC-H200 Tripod Port Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Cyber-shot DSC-H200 Tripod Port Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the back panel (the LCD and motherboard are exposed).
  5. Sony Cyber-shot DSC-H200 Tripod Port Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a screwdriver, remove the three 4mm screws that attach the LCD to the camera motherboard. (The LCD is contained in a holding plate, attached to the motherboard with a ribbon cable.)
  6. Sony Cyber-shot DSC-H200 Tripod Port Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a screwdriver, remove the single 4mm screw at the bottom of the holding plate.
  7. Sony Cyber-shot DSC-H200 Tripod Port Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Cyber-shot DSC-H200 Tripod Port Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the holding plate away from the motherboard and set aside.
  8. Sony Cyber-shot DSC-H200 Tripod Port Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using tweezers, open the LCD ribbon port by lifting the black hinge. (The LCD ribbon cable will detach.)
  9. Sony Cyber-shot DSC-H200 Tripod Port Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Cyber-shot DSC-H200 Tripod Port Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Cyber-shot DSC-H200 Tripod Port Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using tweezers, remove the LCD with the ribbon cable and set aside.
  10. Sony Cyber-shot DSC-H200 Tripod Port Replacement, Motherboard: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the four amber-colored ribbon cables from the motherboard using tweezers.
  11. Sony Cyber-shot DSC-H200 Tripod Port Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect all wires from the motherboard by using a soldering iron.
    • Users unfamiliar with a soldering iron should be extremely careful as the device can get very hot.
  12. Sony Cyber-shot DSC-H200 Tripod Port Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift the motherboard away from the camera body.
  13. Sony Cyber-shot DSC-H200 Tripod Port Replacement, Tripod Port: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a screwdriver, remove the four 4mm screws from the motherboard.
    • Then remove the single 4mm screw connecting the motherboard to the main body of the camera.
  14. Sony Cyber-shot DSC-H200 Tripod Port Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the motherboard away from the camera body (the tripod port is exposed)
  15. Sony Cyber-shot DSC-H200 Tripod Port Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Cyber-shot DSC-H200 Tripod Port Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Cyber-shot DSC-H200 Tripod Port Replacement: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using tweezers, lift the tripod port up and away from the camera body
Chantilly Higbee
crwdns2935283:004/08/15crwdne2935283:0
152 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team 2-3, Matresse Spring 2015 crwdns2935289:0Eastern Washington University, Team 2-3, Matresse Spring 2015crwdne2935289:0
EWU-MATRESSE-S15S2G3
crwdns2942667:0crwdne2942667:0 1,427
