Slide open the battery cover and remove the battery and the Memory Stick Duo.
Return the battery cover to its closed position.
Remove all three screws from the bottom of the camera.
Remove the screws on the left and right sides of the camera.
Press down on the flash cover to raise the flash.
Remove both screws that hold the flash cover to the body of the camera.
Place the camera upside down with the battery port positioned upward.
Slide open the battery port.
Pry the front cover of the camera off with the plastic opening tool.
I need a new battery port. It has a broken lid and doesn’t keep it closed. Anyone knows where can I get one?
