Sony Cyber-Shot DSC-W830 LCD Replacement
Addyson Salalila
crwdns2944107:0crwdnd2944107:0Addyson Salalilacrwdnd2944107:0crwdnd2944107:0crwdnd2944107:05crwdnd2944107:0crwdne2944107:0
crwdns2944111:0December 24, 2016crwdne2944111:0
crwdns2931287:010crwdne2931287:0
crwdns2937801:0crwdne2937801:0
crwdns2942287:0crwdne2942287:0
This will show you how to disassemble the camera and show you how to safely and successfully remove the LCD.
crwdns2944105:0crwdne2944105:0
  1. Sony Cyber-Shot DSC-W830 LCD Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the lock at the bottom of the camera to "Open".
    • The door to the battery pack is spring loaded.
  2. Sony Cyber-Shot DSC-W830 LCD Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the blue clip up and away from the battery.
  3. Sony Cyber-Shot DSC-W830 LCD Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery.
  4. Sony Cyber-Shot DSC-W830 LCD Replacement, Front and Back Panel: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Cyber-Shot DSC-W830 LCD Replacement, Front and Back Panel: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Cyber-Shot DSC-W830 LCD Replacement, Front and Back Panel: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the six 3.5mm Phillips #000 screws.
    • Rotate the lock away from the camera.
  5. Sony Cyber-Shot DSC-W830 LCD Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Cyber-Shot DSC-W830 LCD Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Cyber-Shot DSC-W830 LCD Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pry the device open with the plastic opening tool.
    • There are two clips that help prevent the front panel from separating.
    There is also a small corner piece, coloured the same as camera body, at the battery compartment corner which will also fall out. be careful not to loose it - it’s a bit fidly to fit back when re-assembling, but logcal. The Ifixit tweezers where a great help in locating it back on its pins.
    Nicholas Smith - crwdns2934203:0crwdne2934203:0
  6. Sony Cyber-Shot DSC-W830 LCD Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Cyber-Shot DSC-W830 LCD Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Cyber-Shot DSC-W830 LCD Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two plastic spacers between the front and the back panels.
    • The spacers may fall out when removing the panels.
    • Carefully remove the back panel.
  7. Sony Cyber-Shot DSC-W830 LCD Replacement, Button Board: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Cyber-Shot DSC-W830 LCD Replacement, Button Board: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently release the button board from the clips.
    • Be careful when lifting the button board; the ribbon cable will still be attached.
  8. Sony Cyber-Shot DSC-W830 LCD Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Cyber-Shot DSC-W830 LCD Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the no-fuss ribbon cable by gently pulling it out of the button board.
  9. Sony Cyber-Shot DSC-W830 LCD Replacement, LCD: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Cyber-Shot DSC-W830 LCD Replacement, LCD: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push the bottom right corner of the LCD screen out and slide it to the right to release it from the clips.
    • Be careful when lifting the LCD screen; the ribbon cable will still be attached.
  10. Sony Cyber-Shot DSC-W830 LCD Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Cyber-Shot DSC-W830 LCD Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grasp the no-fuss ribbon cable and gently pull it out from the motherboard.
Addyson Salalila
crwdns2935283:009/15/16crwdne2935283:0
313 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 17-1, Blackwell Fall 2016 crwdns2935289:0USF Tampa, Team 17-1, Blackwell Fall 2016crwdne2935289:0
USFT-BLACKWELL-F16S17G1
crwdns2947412:05crwdne2947412:0
Sony Cyber-Shot DSC-W830 LCD ……WowObjects LCD Display Screen For SONY DSC-W150 same hai ya different hai
tajbhatnagar - crwdns2934203:0crwdne2934203:0
Hi I need a one DSC w810 display how much. ?
How can contact you ?
Tamil Varshitha - crwdns2934203:0crwdne2934203:0
Sony dsc s2000 model camera need
Display & lens unit
crwdns2936753:030crwdne2936753:0 46
crwdns2942667:0crwdne2942667:0 4,829
