If you have broken the outer panels of your DSC-W830, do not worry. This guide will take you through the correct steps of remove both the front and back panels.
Slide the lock at the bottom of the camera to "Open".
Slide the blue clip up and away from the battery.
Remove the six 3.5mm Phillips #000 screws.
Rotate the lock away from the camera.
Pry the device open with the plastic opening tool.
Remove the two plastic spacers between the front and the back panels.
Carefully remove the back panel.
