Sony Cyber-Shot DSC-W170 Lens Assembly Replacement
  1. Sony Cyber-Shot DSC-W170 Lens Assembly Replacement, LCD Panel Assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Cyber-Shot DSC-W170 Lens Assembly Replacement, LCD Panel Assembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Cyber-Shot DSC-W170 Lens Assembly Replacement, LCD Panel Assembly: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Be sure to remove the battery before performing this task.
    • Remove the five 4 mm screws with a Phillips #000 screwdriver.
  2. Sony Cyber-Shot DSC-W170 Lens Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use an opening pick to pry the LCD panel open.
  3. Sony Cyber-Shot DSC-W170 Lens Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently remove the LCD panel from the rest of the camera.
  4. Sony Cyber-Shot DSC-W170 Lens Assembly Replacement, Front Panel: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Cyber-Shot DSC-W170 Lens Assembly Replacement, Front Panel: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Cyber-Shot DSC-W170 Lens Assembly Replacement, Front Panel: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the three 4 mm screws with a Phillips #000 screwdriver.
  5. Sony Cyber-Shot DSC-W170 Lens Assembly Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently open the front panel and remove it from the rest of the camera.
  6. Sony Cyber-Shot DSC-W170 Lens Assembly Replacement, LCD: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Cyber-Shot DSC-W170 Lens Assembly Replacement, LCD: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the first side panel to the left of the LCD.
    • Remove the 4 mm screw from the other side panel to the right of the LCD with a Phillips #000 screwdriver.
  7. Sony Cyber-Shot DSC-W170 Lens Assembly Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Cyber-Shot DSC-W170 Lens Assembly Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Cyber-Shot DSC-W170 Lens Assembly Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently, lift the LCD and carefully open the camera to disconnect the LCD ribbon cable from the motherboard.
  8. Sony Cyber-Shot DSC-W170 Lens Assembly Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Cyber-Shot DSC-W170 Lens Assembly Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently push the connector through the hole to separate the LCD from the metal casing.
  9. Sony Cyber-Shot DSC-W170 Lens Assembly Replacement, Top Panel: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Cyber-Shot DSC-W170 Lens Assembly Replacement, Top Panel: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift up the black bar on the top flat ribbon cable with tweezers.
    • Gently pull the flat ribbon cable until it disconnects from the lens assembly.
    • Be gentle when dealing with the flat ribbon cable.
  10. Sony Cyber-Shot DSC-W170 Lens Assembly Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Cyber-Shot DSC-W170 Lens Assembly Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Cyber-Shot DSC-W170 Lens Assembly Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the six 4 mm screws from the lens assembly with a Phillips #000 screwdriver.
  11. Sony Cyber-Shot DSC-W170 Lens Assembly Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the two flat ribbon cables with tweezers.
  12. Sony Cyber-Shot DSC-W170 Lens Assembly Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Peel back the flash assembly on the back of the lens.
    • Remove the two 4 mm screws with a Phillips #000 screwdriver.
  13. Sony Cyber-Shot DSC-W170 Lens Assembly Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull out the battery from the side and remove the white tape from the battery assembly with tweezers.
  14. Sony Cyber-Shot DSC-W170 Lens Assembly Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Cyber-Shot DSC-W170 Lens Assembly Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the flat ribbon cable that connects the motherboard to the lens assembly with tweezers.
  15. Sony Cyber-Shot DSC-W170 Lens Assembly Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Push out the lens assembly very gently.
  16. Sony Cyber-Shot DSC-W170 Lens Assembly Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 4 mm screw from the bottom side of the top panel with a Phillips #000 screwdriver.
  17. Sony Cyber-Shot DSC-W170 Lens Assembly Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the silver 4 mm screw with a Phillips #000 screwdriver from the silver bracket connected to the motherboard.
  18. Sony Cyber-Shot DSC-W170 Lens Assembly Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the top panel off gently.
  19. Sony Cyber-Shot DSC-W170 Lens Assembly Replacement, Lens Assembly: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Desolder the wires connecting the top panel circuit board from the lens with the soldering iron.
    • Be careful with the soldering iron; it will be hot.
Katharina Anglett
crwdns2935283:009/13/23crwdne2935283:0
529 crwdns2915208:0crwdne2915208:0
University of North Texas, Team 4-12, Harold Fall 2023 crwdns2935289:0University of North Texas, Team 4-12, Harold Fall 2023crwdne2935289:0
UNT-HAROLD-F23S4G12
crwdns2942667:0crwdne2942667:0 508
