Sony Cyber-Shot DSC-TX9 Lens Replacement
  1. Sony Cyber-Shot DSC-TX9 Lens Replacement, Prerequisites Only: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Cyber-Shot DSC-TX9 Lens Replacement, Prerequisites Only: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Cyber-Shot DSC-TX9 Lens Replacement, Prerequisites Only: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #0 screwdriver to unscrew the six 2mm screws on the outer case of the camera.
    • If there is a battery or SD card inside remove before beginning the process.
  2. Sony Cyber-Shot DSC-TX9 Lens Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Cyber-Shot DSC-TX9 Lens Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your hands or a Spudger to Pull off the front cover of the camera.
    • If the casing is not coming apart easily, do not force it.
  3. Sony Cyber-Shot DSC-TX9 Lens Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the protective black cover layer with your hands and set it aside.
    • The use of tweezers may be necessary if the cover is difficult to remove.
  4. Sony Cyber-Shot DSC-TX9 Lens Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Cyber-Shot DSC-TX9 Lens Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The ZIF connector can be removed by flipping the small black holder into the upright position and then sliding the ribbon cable out carefully.
    • Once this has been done, use tweezers to unplug the flat topped connector for the lens’ circuit board from the motherboard.
    • DO NOT force the ribbon cables or they will rip.
    • Refer to the (Recognizing & Disconnecting Cable Connectors) page for assistance.
  5. Sony Cyber-Shot DSC-TX9 Lens Replacement, Lens: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the tweezers carefully remove the broken/damaged lens with its attached circuit board
robert.oliver6
crwdns2935283:003/23/17crwdne2935283:0
110 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S4-G3, Julie Spring 2017 crwdns2935289:0UMass Dartmouth, Team S4-G3, Julie Spring 2017crwdne2935289:0
UMASSD-JULIE-S17S4G3
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 542
