Sony Cyber-Shot DSC-S90 LCD Display Replacement
  1. Sony Cyber-Shot DSC-S90 LCD Display Replacement, Batteries: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Cyber-Shot DSC-S90 LCD Display Replacement, Batteries: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Hold down the "open"button (gray oval with arrow pointing upwards) on the battery port door.
    • While holding the button downwards, slide the door upwards to unlock and open the door.
  2. Sony Cyber-Shot DSC-S90 LCD Display Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull open the door and allow the batteries to fall out.
  3. Sony Cyber-Shot DSC-S90 LCD Display Replacement, Back Case: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Cyber-Shot DSC-S90 LCD Display Replacement, Back Case: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 2mm Phillips #00 screw under the battery port door.
    • Remove the 2mm Phillips #00 screw towards the right of the bottom-side of the camera.
  4. Sony Cyber-Shot DSC-S90 LCD Display Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Cyber-Shot DSC-S90 LCD Display Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 2mm Phillips #00 screws (one on each side of the camera).
  5. Sony Cyber-Shot DSC-S90 LCD Display Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Cyber-Shot DSC-S90 LCD Display Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use an opening tool to unlock the front case from the main body of the camera. Use the tool on the right side and bottom of the camera with the LCD screen facing you.
  6. Sony Cyber-Shot DSC-S90 LCD Display Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull apart the back case from the main body of the camera.
  7. Sony Cyber-Shot DSC-S90 LCD Display Replacement, Front Case: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use an opening tool to unlock the front case from the main body of the camera. Use the tool on the top of the camera.
  8. Sony Cyber-Shot DSC-S90 LCD Display Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull apart the front case from the main body of the camera.
  9. Sony Cyber-Shot DSC-S90 LCD Display Replacement, Top/Side Case: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Cyber-Shot DSC-S90 LCD Display Replacement, Top/Side Case: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Cyber-Shot DSC-S90 LCD Display Replacement, Top/Side Case: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Release all clips and latches keeping the casing in place using a spudger, opening tool, or screwdriver.
  10. Sony Cyber-Shot DSC-S90 LCD Display Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Now the casing can be removed after all latches have been undone.
  11. Sony Cyber-Shot DSC-S90 LCD Display Replacement, Battery Terminal: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Cyber-Shot DSC-S90 LCD Display Replacement, Battery Terminal: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Cyber-Shot DSC-S90 LCD Display Replacement, Battery Terminal: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the ribbon cables on top of the battery terminal using a spudger or screwdriver.
  12. Sony Cyber-Shot DSC-S90 LCD Display Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the remaining ribbon cable on the side of the camera using a spudger or screwdriver.
  13. Sony Cyber-Shot DSC-S90 LCD Display Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger or screwdriver to unhinge the clips. This releases the battery terminal.
  14. Sony Cyber-Shot DSC-S90 LCD Display Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the battery terminal is unclipped, pull this ribbon cable out with a spudger or screwdriver to finish freeing the battery terminal.
  15. Sony Cyber-Shot DSC-S90 LCD Display Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Now the battery terminal can be separated from the main body of the camera.
  16. Sony Cyber-Shot DSC-S90 LCD Display Replacement, Motherboard: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Cyber-Shot DSC-S90 LCD Display Replacement, Motherboard: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Cyber-Shot DSC-S90 LCD Display Replacement, Motherboard: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the three pictured ribbon cables using a spudger or screwdriver.
  17. Sony Cyber-Shot DSC-S90 LCD Display Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Push the clip to the left and lift the motherboard upwards and away from the camera.
  18. Sony Cyber-Shot DSC-S90 LCD Display Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Cyber-Shot DSC-S90 LCD Display Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the two ribbon cables using a spudger or screwdriver.
  19. Sony Cyber-Shot DSC-S90 LCD Display Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unlatch the clip and lift the motherboard upwards and away from the camera.
  20. Sony Cyber-Shot DSC-S90 LCD Display Replacement, LCD Display: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Cyber-Shot DSC-S90 LCD Display Replacement, LCD Display: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unlatch the two clips holding the LCD display onto the main camera housing using a spudger.
  21. Sony Cyber-Shot DSC-S90 LCD Display Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the LCD.
Jonathan Arns
crwdns2935283:010/28/19crwdne2935283:0
748 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S4-G5, Saloman Fall 2019 crwdns2935289:0UMass Dartmouth, Team S4-G5, Saloman Fall 2019crwdne2935289:0
UMASSD-SALOMAN-F19S4G5
crwdns2935297:020crwdne2935297:0
crwdns2942667:0crwdne2942667:0 492
