Sony Clie PEG-NR70 Memory Module Replacement
  1. Sony Clie PEG-NR70 Memory Module Replacement, The Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the 1.9mm screw located at the top of the device with a Phillips #00 screwdriver.
    • It may be helpful to set up a piece of paper to keep track of where removed screws came from.
  2. Sony Clie PEG-NR70 Memory Module Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the 2.5mm screw located on the left side of the device with a Phillips #00 screwdriver.
  3. Sony Clie PEG-NR70 Memory Module Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Clie PEG-NR70 Memory Module Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the five 2.5mm screws on the back panel with a Phillips #00 screwdriver.
    • Remove the back panel by lifting it away with your hands.
  4. Sony Clie PEG-NR70 Memory Module Replacement, Memory Module: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Holding the memory module in place, unscrew the three 0.9mm screws with a Phillips #00 screwdriver.
  5. Sony Clie PEG-NR70 Memory Module Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lightly grab the memory module and pull it upwards.
    • Make sure you grab the end closest to the edge of the device. You may have to wiggle the module a bit to get it to come free.
Daniel Soski
crwdns2935283:004/18/13crwdne2935283:0
63 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 14-11, Maness Spring 2013 crwdns2935289:0Cal Poly, Team 14-11, Maness Spring 2013crwdne2935289:0
CPSU-MANESS-S13S14G11
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 676
