Sony CFD-8 Motor Belt Replacement
  1. Sony CFD-8 Motor Belt Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony CFD-8 Motor Belt Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony CFD-8 Motor Belt Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the battery cover on the back of the boombox by applying downward pressure to the two clamps.
    • Be sure to unplug the boombox from the wall before attempting to open it for repair.
  2. Sony CFD-8 Motor Belt Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony CFD-8 Motor Belt Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push against the positive end of each battery. Once it is loose, lift the battery out. Repeat for all six batteries.
    • The top row of batteries have the positive side pointing right. The bottom row of batteries have the positive side pointing left.
  3. Sony CFD-8 Motor Belt Replacement, Front Panel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony CFD-8 Motor Belt Replacement, Front Panel: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony CFD-8 Motor Belt Replacement, Front Panel: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Hold the boombox handle at an angle to access the screws behind the CD player.
    • Use a Phillips #1 screwdriver to unscrew the top two 14 mm screws. You may need a flashlight to see the screws.
  4. Sony CFD-8 Motor Belt Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony CFD-8 Motor Belt Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove four 14 mm screws using a Phillips #1 screwdriver. Two of these screws are at the bottom of the boombox and the other two are on either side of the boombox as highlighted in the related images.
    • All four screws have black arrows (not visible in the photo) indicating their location on the boombox.
  5. Sony CFD-8 Motor Belt Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony CFD-8 Motor Belt Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony CFD-8 Motor Belt Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently separate the front panel from the back panel.
    • Remove the two connections holding the front panel to boombox.
    • One connection is located on the upper left hand side of the main circuit board.
    • The other is a large white strip slightly to the right of the cassette player.
    • Do not touch the cylindrical parts on the circuit board. These are capacitors and may deliver a shock!
    • Remove the front panel.
  6. Sony CFD-8 Motor Belt Replacement, Remove Gear Assembly: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the 3x12 screws circled in the photo using a #1 Phillips screwdriver.
  7. Sony CFD-8 Motor Belt Replacement, Disconnect Wires: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully disconnect the wire connection by pulling at its base.
  8. Sony CFD-8 Motor Belt Replacement, Remove Motor: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony CFD-8 Motor Belt Replacement, Remove Motor: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony CFD-8 Motor Belt Replacement, Remove Motor: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the 5mm screw shown in the photo.
    • Note the small latch on the side of assembly as you remove the motor.
  9. Sony CFD-8 Motor Belt Replacement, Replace Motor Belt: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony CFD-8 Motor Belt Replacement, Replace Motor Belt: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the motor belt from its axle.
Wil Gilbreath
crwdns2935283:010/14/14crwdne2935283:0
205 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 10-38, Amido Fall 2014 crwdns2935289:0Cal Poly, Team 10-38, Amido Fall 2014crwdne2935289:0
CPSU-AMIDO-F14S10G38
need belt for cassette replace
joe jefferson - crwdns2934203:0crwdne2934203:0
need the belt for the cassette player
First, be sure to have a #1 pt screwdriver with at least a 5” shaft(not counting the handle) length. Second, pay attention to where the screws under the handle are located. Third, mark the top of the connectors with a sharpie or such instrument to be sure you are replacing the connector in the correct position.
Don Gunkel - crwdns2934203:0crwdne2934203:0
Here's some information about the belts needed, which may be especially useful if your old belts have turned to goo like mine! Two identical belts are needed: the Sony part number is 3-362-989-01, and generic names appear to include SBO5.2 and SCY5.2. It's a square belt with 1 mm thickness and an inside diameter of 5.2 inches. I found that the most economical way to purchase these was to get a bulk bag of 1 mm square belts of mixed length.
SandStone - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 54
crwdns2942667:0crwdne2942667:0 14,138
