crwdns2959928:0crwdne2959928:0 ↓This will be the initial step for getting into your device for repair.
Before any repair work can be done, one must remove the device from the vehicle. To do so follow this link to see a vehicle general removal of a stereo system.
Locate face-plate eject button.
Press the eject button.
Remove the face-plate.
Remove two 4.9mm Phillips #00screws on the front of the device.
Remove two 7.5mm Phillips #00screws on the front of the device.
Rotate device 90 degrees to either side.
Use the plastic opening tool to pry open the top and bottom tab respectively.
Repeat on opposite side.
