Sony CDX-GT540UI CD Drive Replacement
  1. Sony CDX-GT540UI CD Drive Replacement, Front Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate face-plate eject button.
  2. Sony CDX-GT540UI CD Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony CDX-GT540UI CD Drive Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Press the eject button.
    • Remove the face-plate.
  3. Sony CDX-GT540UI CD Drive Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony CDX-GT540UI CD Drive Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony CDX-GT540UI CD Drive Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove two 4.9mm Phillips #00screws on the front of the device.
    • Remove two 7.5mm Phillips #00screws on the front of the device.
    • When the screws are removed, the eject lever may fall into the device. Make sure the device is held horizontal and level.
  4. Sony CDX-GT540UI CD Drive Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony CDX-GT540UI CD Drive Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Rotate device 90 degrees to either side.
    • Use the plastic opening tool to pry open the top and bottom tab respectively.
    • Repeat on opposite side.
  5. Sony CDX-GT540UI CD Drive Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove front panel.
  6. Sony CDX-GT540UI CD Drive Replacement, Back Panel: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate back panel.
  7. Sony CDX-GT540UI CD Drive Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony CDX-GT540UI CD Drive Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony CDX-GT540UI CD Drive Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove four 11.5mm Phillips #00 (silver) screws from back panel.
  8. Sony CDX-GT540UI CD Drive Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove four 9.5mm Phillips #00 (black) screws from back panel.
    • Remove two 7.5mm Phillips #00 (black) screws from back panel.
  9. Sony CDX-GT540UI CD Drive Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove back panel.
    • On the back panel there will be thermal (white) paste. Do not touch.
  10. Sony CDX-GT540UI CD Drive Replacement, CD Drive: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove one 9.5mm Phillips #00 screw.
    • Rotate device 180 degrees and repeat step.
  11. Sony CDX-GT540UI CD Drive Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony CDX-GT540UI CD Drive Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using plastic opening tool, detach the tabs. There are two on either side.
    • You will need to apply a decent amount of force to detach.
  12. Sony CDX-GT540UI CD Drive Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony CDX-GT540UI CD Drive Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove top panel.
  13. Sony CDX-GT540UI CD Drive Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull up CD drive slightly.
  14. Sony CDX-GT540UI CD Drive Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect motherboard connection.
  15. Sony CDX-GT540UI CD Drive Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove CD drive.
Odelkys Marquez
crwdns2935283:009/22/14crwdne2935283:0
1,139 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 10-2, Brown Fall 2014 crwdns2935289:0USF Tampa, Team 10-2, Brown Fall 2014crwdne2935289:0
USFT-BROWN-F14S10G2
This guide is listed as "difficult" yet only requires the use of a screwdriver and some prying tools. It would seem more appropriate to list it as "moderate" at most. I believe the motherboard guide has the same issue.
Also, you say PH#00 in the description of steps, but in the "tools" listing at the beginning of the guide, you said that a PH#0 was needed. These are not the same.
Dale Pearson - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 832
