Sony CDX-GT540UI CD Drive Replacement
crwdns2869540:0crwdne2869540:0: 1,3 k
2
13
82
1 322
crwdns2955950:0crwdne2955950:0: 5
crwdns2960004:04crwdne2960004:0, crwdns2960006:01crwdne2960006:0
crwdns2959984:0crwdne2959984:0: 2
crwdns2959974:02crwdne2959974:0
crwdns2955944:0crwdne2955944:0: 15 - 20 crwdns2931279:0crwdne2931279:0
This will show one how to remove and replace the CD drive.
Before any repair work can be done one must remove the device for the vehicle. To do so follow this link to see a general vehicle removal of a stereo system.
    1. Sony CDX-GT540UI CD Drive Replacement, Front Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Locate face-plate eject button.
    2. Sony CDX-GT540UI CD Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony CDX-GT540UI CD Drive Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Press the eject button.
      • Remove the face-plate.
    3. Sony CDX-GT540UI CD Drive Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony CDX-GT540UI CD Drive Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony CDX-GT540UI CD Drive Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove two 4.9mm Phillips #00screws on the front of the device.
      • Remove two 7.5mm Phillips #00screws on the front of the device.
      • When the screws are removed, the eject lever may fall into the device. Make sure the device is held horizontal and level.
    4. Sony CDX-GT540UI CD Drive Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony CDX-GT540UI CD Drive Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Rotate device 90 degrees to either side.
      • Use the plastic opening tool to pry open the top and bottom tab respectively.
      • Repeat on opposite side.
    5. Sony CDX-GT540UI CD Drive Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove front panel.
    1. Sony CDX-GT540UI CD Drive Replacement, Back Panel: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Locate back panel.
    2. Sony CDX-GT540UI CD Drive Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony CDX-GT540UI CD Drive Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony CDX-GT540UI CD Drive Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove four 11.5mm Phillips #00 (silver) screws from back panel.
    3. Sony CDX-GT540UI CD Drive Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove four 9.5mm Phillips #00 (black) screws from back panel.
      • Remove two 7.5mm Phillips #00 (black) screws from back panel.
    4. Sony CDX-GT540UI CD Drive Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove back panel.
      • On the back panel there will be thermal (white) paste. Do not touch.
    1. Sony CDX-GT540UI CD Drive Replacement, CD Drive: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove one 9.5mm Phillips #00 screw.
      • Rotate device 180 degrees and repeat step.
    2. Sony CDX-GT540UI CD Drive Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony CDX-GT540UI CD Drive Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using plastic opening tool, detach the tabs. There are two on either side.
      • You will need to apply a decent amount of force to detach.
    3. Sony CDX-GT540UI CD Drive Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony CDX-GT540UI CD Drive Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove top panel.
    4. Sony CDX-GT540UI CD Drive Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Pull up CD drive slightly.
    5. Sony CDX-GT540UI CD Drive Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Disconnect motherboard connection.
    6. Sony CDX-GT540UI CD Drive Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove CD drive.
Odelkys Marquez
crwdns2935283:009/22/14crwdne2935283:0
1 139 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 10-2, Brown Fall 2014 crwdns2935289:0USF Tampa, Team 10-2, Brown Fall 2014crwdne2935289:0
USFT-BROWN-F14S10G2
crwdns2935297:084crwdne2935297:0
This guide is listed as "difficult" yet only requires the use of a screwdriver and some prying tools. It would seem more appropriate to list it as "moderate" at most. I believe the motherboard guide has the same issue.
Also, you say PH#00 in the description of steps, but in the "tools" listing at the beginning of the guide, you said that a PH#0 was needed. These are not the same.
Dale Pearson - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 82
crwdns2959996:0crwdne2959996:0 1,322
