Sony Bloggie 3D Player USB Drive Replacement
  1. Sony Bloggie 3D Player USB Drive Replacement, Front Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 2.5mm Phillips #00 screws using the Philips #00 screwdriver.
  2. Sony Bloggie 3D Player USB Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Bloggie 3D Player USB Drive Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a plastic opening tool to pry the cover open.
    • After the the cover is partly open as shown, remove the cover with your hands.
  3. Sony Bloggie 3D Player USB Drive Replacement, Back Cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Bloggie 3D Player USB Drive Replacement, Back Cover: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using your hand, or a pair of tweezers, remove the ZIF connector by gently pulling it out of the dock on the circuit board.
  4. Sony Bloggie 3D Player USB Drive Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Bloggie 3D Player USB Drive Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a plastic opening tool to loosen the back cover off the device.
    • Once the back cover is loose, remove it gently by hand.
  5. Sony Bloggie 3D Player USB Drive Replacement, USB Drive: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Bloggie 3D Player USB Drive Replacement, USB Drive: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once the back cover is removed, by using the opening tool, remove the following screws using a Phillips #00 screwdriver.
    • Two 4.0mm Phillips #00 screws
    • One 8.0mm Phillips #00 screw
    • One 9.5mm Phillips #00 screw
  6. Sony Bloggie 3D Player USB Drive Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Bloggie 3D Player USB Drive Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a spudger, remove the clips of the metal casing from each end of the USB drive.
  7. Sony Bloggie 3D Player USB Drive Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Bloggie 3D Player USB Drive Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully lift the USB drive off of the peg that it is attached to.
  8. Sony Bloggie 3D Player USB Drive Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Now that the USB component is on its own, untangle the ribbon from inside the device.
  9. Sony Bloggie 3D Player USB Drive Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Now remove the ZIF connector from the device using a pair of tweezers.
Craig Sweet
crwdns2935283:001/11/13crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 7-12, Maness Winter 2013 crwdns2935289:0Cal Poly, Team 7-12, Maness Winter 2013crwdne2935289:0
CPSU-MANESS-W13S7G12
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 559
