Sony BDP-S3700 Motherboard Replacement
  1. Sony BDP-S3700 Motherboard Replacement, Front Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony BDP-S3700 Motherboard Replacement, Front Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the PH1 screwdriver to remove the two 9mm screws on the back of the Blu-ray player.
  2. Sony BDP-S3700 Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony BDP-S3700 Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the back of the device by slowly sliding the rear outer housing backwards.
  3. Sony BDP-S3700 Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony BDP-S3700 Motherboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the Blu-ray over
    • Pry open the clips under and on the sides
  4. Sony BDP-S3700 Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once all the clips are open, slide the front outer housing out.
  5. Sony BDP-S3700 Motherboard Replacement, Disc Drive: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony BDP-S3700 Motherboard Replacement, Disc Drive: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony BDP-S3700 Motherboard Replacement, Disc Drive: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the Blu-ray back up
    • Remove the three ribbon cables that connect the disc drive to the motherboard.
    • Handle the circuits only on its side.
  6. Sony BDP-S3700 Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony BDP-S3700 Motherboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a PH1 screwdriver to unscrew both of the 7mm screws on the side of the disc reader.
  7. Sony BDP-S3700 Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently slide the disc drive to the right and lift up to remove the disc drive from the body of the player.
  8. Sony BDP-S3700 Motherboard Replacement, Motherboard: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony BDP-S3700 Motherboard Replacement, Motherboard: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pull upwards on the ribbon cables to disconnect the motherboard from the Wi-Fi module and port board.
  9. Sony BDP-S3700 Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony BDP-S3700 Motherboard Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony BDP-S3700 Motherboard Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the three 7mm screws along the motherboard using a PH1 screwdriver.
  10. Sony BDP-S3700 Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony BDP-S3700 Motherboard Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony BDP-S3700 Motherboard Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 4mm screw above the HDMI port and the 9mm screw Digital Out port.
  11. Sony BDP-S3700 Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully lift and pull the motherboard forward to remove.
    quiero saber xq mi blue ray sony bdp s 6700 se queda en el logo de la marca y no iinicia podrias ayumarme con eso
    dayhiro1016 - crwdns2934203:0crwdne2934203:0
Luiz Barreto
crwdns2935283:002/15/17crwdne2935283:0
627 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 12-1, Eyestone Spring 2017 crwdns2935289:0USF Tampa, Team 12-1, Eyestone Spring 2017crwdne2935289:0
USFT-EYESTONE-S17S12G1
Thanks for the guide really good! Does anyone know where i can get a sony bdp-s3700 motherboard replacement?
James Durham - crwdns2934203:0crwdne2934203:0
Same problem here.
Julian Robbins -
crwdns2942667:0crwdne2942667:0 1,612
