This is a brief guide that demonstrates how to remove the front panel from your Sony BDP-S3700.
Use the PH1 screwdriver to remove the two 9mm screws on the back of the Blu-ray player.
Remove the back of the device by slowly sliding the rear outer housing backwards.
Turn the Blu-ray over
Pry open the clips under and on the sides
Once all the clips are open, slide the front outer housing out.
