Use this guide to replace the motherboard in your device.
Remove all cables from the device.
Use a #1 Phillips screwdriver to remove the three screws located in the back of the device.
Pull the top cover off by sliding back from the device once the screws have been taken out.
Carefully detach the white strips from the motherboard.
Remove screw above HDMI OUT port.
Remove screw above DIGITAL OUT port.
Remove the three screws on the motherboard.
