Sony BDP-S1: Getting inside the device
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. Sony BDP-S1: Getting inside the device, Sony BDP-S1: Getting inside the device: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony BDP-S1: Getting inside the device, Sony BDP-S1: Getting inside the device: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 12mm screws with the Philips #2 screwdriver which keep the plastic panels in place.
    • Don't forget, there are two more 12mm screws on the other side as well.
  2. Sony BDP-S1: Getting inside the device: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony BDP-S1: Getting inside the device: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony BDP-S1: Getting inside the device: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • First, remove the three 12mm black screws holding the top panel on (Phillips #2).
    • Then, remove the two 12mm black screws - one on each side of the back of the device - holding the top panel on.
    • Lastly, remove the three 12mm black screws on each side of device.
  3. Sony BDP-S1: Getting inside the device: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony BDP-S1: Getting inside the device: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony BDP-S1: Getting inside the device: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully lift up the top panel, because there are two blue ribbon cables that must be disconnected before removing the panel, and we do NOT want them to break.
    • After gently disconnecting the two ribbon cables (you can just pull them out with your hand), take the top off and set it to the side.
  4. Sony BDP-S1: Getting inside the device: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony BDP-S1: Getting inside the device: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony BDP-S1: Getting inside the device: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • After the top is off, you'll see that there are two metal bars that go across the top of the device.
    • Remove each bar by unscrewing the two 10mm silver screws on each end.
Sam
crwdns2935283:001/26/14crwdne2935283:0
376 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 9-30, Maness Winter 2014 crwdns2935289:0Cal Poly, Team 9-30, Maness Winter 2014crwdne2935289:0
CPSU-MANESS-W14S9G30
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 73
