Sony BDP-BX510 Wi-Fi Module Replacement
  1. Sony BDP-BX510 Wi-Fi Module Replacement, Outer Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Plug in the device to turn it on, then press the eject ( ⏏ ) button to open the tray.
  2. Sony BDP-BX510 Wi-Fi Module Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony BDP-BX510 Wi-Fi Module Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To remove the tray cover, hold both sides of the tray cover and gently apply a downward pressure.
    • Apply slightly more pressure to the left side until it unhooks then unhook the right side.
    • Close the disk tray by pressing the eject button again, then power off the device and unplug it.
    • Do not use too much force to remove the tray cover as you may break it.
  3. Sony BDP-BX510 Wi-Fi Module Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony BDP-BX510 Wi-Fi Module Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn to the back of the device.
    • Remove the two 7mm Phillips #2 screws.
    • Slide the two plastic covers on both sides of the device towards the back of the device to remove them.
  4. Sony BDP-BX510 Wi-Fi Module Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony BDP-BX510 Wi-Fi Module Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony BDP-BX510 Wi-Fi Module Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the device so you can see the bottom.
    • Unclip the three black plastic clips on the bottom of the device.
    • Unclip one clip on each side of the device.
  5. Sony BDP-BX510 Wi-Fi Module Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the cover forward to remove.
  6. Sony BDP-BX510 Wi-Fi Module Replacement, Port Board: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Find the large ribbon cable that connects the port board to the motherboard.
    • Carefully pull directly upwards to disconnect the cable.
  7. Sony BDP-BX510 Wi-Fi Module Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the Phillips #1 screwdriver, remove the 5mm screwdriver attached to the port board.
  8. Sony BDP-BX510 Wi-Fi Module Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unclip the metal piece on the lower right corner by gently lifting it up.
  9. Sony BDP-BX510 Wi-Fi Module Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the port board by simply pulling it away from the device.
  10. Sony BDP-BX510 Wi-Fi Module Replacement, Wi-Fi Module: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the cable that attaches the Wi-Fi module to the motherboard.
    • The cable will be hard to remove, so pull hard but carefully.
  11. Sony BDP-BX510 Wi-Fi Module Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #1 screwdriver to remove the single 5mm screw that holds Wi-Fi module to the device.
  12. Sony BDP-BX510 Wi-Fi Module Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove the Wi-Fi module from the device.
    • Avoid getting fingerprints on the module.
Niki Ngosi
crwdns2935283:001/19/20crwdne2935283:0
375 crwdns2915208:0crwdne2915208:0
York University, Team S1-G10, Woodhouse Winter 2020 crwdns2935289:0York University, Team S1-G10, Woodhouse Winter 2020crwdne2935289:0
YORK-WOODHOUSE-W20S1G10
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 388
