If you need to access the internal components of your Sony BDP-BX320 Blu-ray player, follow this guide to remove the top case.
Power off and unplug the device from any power source.
Place the Blue-ray player on a clean, stable surface.
crwdns2935267:0crwdne2935267:0Magnetic Project Mat$19.95
Use a Phillips #1 screwdriver to remove the three 8.3 mm screws on the back of the device.
Slide the back section of the top case off the device.
Use your hands or a metal spudger to gently disconnect the case from the small tabs on the bottom and sides of the device.
Slide off the front section of the top case to expose the internal components.
