Sony BDP-BX320 Optical Drive Replacement
  1. Sony BDP-BX320 Optical Drive Replacement, Outer Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Power off and unplug the device from any power source.
    • Place the Blue-ray player on a clean, stable surface.
  2. Sony BDP-BX320 Optical Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony BDP-BX320 Optical Drive Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Magnetic Project Mat
    $19.95
    • If preferred, use the Magnetic Mat to organize screws.
    • Use a Phillips #1 screwdriver to remove the three 8.3 mm screws on the back of the device.
    • Slide the back section of the top case off the device.
  3. Sony BDP-BX320 Optical Drive Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony BDP-BX320 Optical Drive Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony BDP-BX320 Optical Drive Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your hands or a metal spudger to gently disconnect the case from the small tabs on the bottom and sides of the device.
  4. Sony BDP-BX320 Optical Drive Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide off the front section of the top case to expose the internal components.
  5. Sony BDP-BX320 Optical Drive Replacement, Optical Drive: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the optical drive, which is positioned next to the main board and connected by a wide ZIF connector ribbon cable.
  6. Sony BDP-BX320 Optical Drive Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony BDP-BX320 Optical Drive Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony BDP-BX320 Optical Drive Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Phillips #1 Screwdriver
    $5.49
    • Use a Phillips #1 Screwdriver to remove the two 7 mm screws that secure the optical drive to the frame of the device.
    • Use a spudger or a clean fingernail to flip up the locking flap of the ZIF connector located between the two "no fuss" ribbon cables that are attached to the board. This action puts the connector in the unlocked position.
    • Use the widest tool possible to avoid damaging the delicate hinge pins.
    • Use tweezers or your fingers to gently pull the cable out of its socket by the blue tab.
    • You may damage the cable by gripping it directly.
    • To reconnect, make sure the locking flap is flipped up and gently reinsert the cable. Then, flip the locking flap down to secure the cable. The cable should slide into the socket with little to no force. If you're having trouble, remove it, check that the flap is fully unlocked, and try again.
    • Pull the other two "no-fuss" ribbon cables straight out of their socket to disconnect them.
  7. Sony BDP-BX320 Optical Drive Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully lift the optical drive out of the device housing.
By following these steps, you should have successfully replaced the optical drive in your Sony BDP-BX320, and resolved playback issues due to a faulty drive. To reassemble, follow these steps in reverse order. Carefully replace the outer casing if needed and screw it back into place. Ensure all screws are tightened, but avoid overtightening.
Veronika Saiadian
crwdns2935283:009/16/24crwdne2935283:0
315 crwdns2915208:0crwdne2915208:0
CSU Los Angeles, Team 5-2, Kershman Fall 2024 crwdns2935289:0CSU Los Angeles, Team 5-2, Kershman Fall 2024crwdne2935289:0
CSULA-KERSHMAN-F24S5G2
crwdns2931471:06crwdne2931471:0
crwdns2942667:0crwdne2942667:0 157
