Sony BDP BX350 Motherboard Replacement
  1. Sony BDP BX350 Motherboard Replacement, Disc Assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 10mm Philips head screws on the back of the player.
  2. Sony BDP BX350 Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using an opening tool lift up the tabs located on the bottom of the plastic front cover.
  3. Sony BDP BX350 Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the tabs located on each side of the device to free the front cover. Begin to separate the front and metal back covers.
  4. Sony BDP BX350 Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Completely separate the front cover and the metal back cover from the grey casing.
    • The inner components should all be completely exposed after opening.
  5. Sony BDP BX350 Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the two 8mm Philips head screws securing the disc assembly to the main casing.
  6. Sony BDP BX350 Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the disc assembly out from under the metal tabs on the main casing.
  7. Sony BDP BX350 Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove disc assembly.
  8. Sony BDP BX350 Motherboard Replacement, Motherboard: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony BDP BX350 Motherboard Replacement, Motherboard: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Do not bend or tear the ribbon cable.
    • Remove all five ribbon cables from the motherboard.
  9. Sony BDP BX350 Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew 3mm Philips head HDMI screw from metal casing.
  10. Sony BDP BX350 Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the three 5mm Philips head screws from motherboard.
    • Separate the motherboard from the metal casing by pulling directly up. Use an opening tool if necessary.
Kristen Vezina
crwdns2935283:003/06/17crwdne2935283:0
413 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S8-G5, Catania Spring 2017 crwdns2935289:0UMass Dartmouth, Team S8-G5, Catania Spring 2017crwdne2935289:0
UMASSD-CATANIA-S17S8G5
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 661
