crwdns2959928:0crwdne2959928:0 ↓This is a step-by-step guide on how to replace your Sony BDP BX350 Device Control Board. This guide is needed if the device control board or USB drive are faulty. Make sure the device is unplugged before starting this guide.
Remove the three 10mm Philips head screws on the back of the player.
Using an opening tool lift up the tabs located on the bottom of the plastic front cover.
Lift the tabs located on each side of the device to free the front cover. Begin separating the two covers from metal casing.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Using the plastic tweezers, carefully remove the ribbon cable from the motherboard.
Unscrew the one 5mm Phillips head screw from the front of the device board.
Carefully separate the device control board from the metal casing.
