The top panel can be cracked, and it's removal is often needed to access other parts under the top panel.
Turn the camera off by sliding the power switch.
Use a Phillips head 000 screwdriver to remove the 4.0mm screw inside the USB port.
Use a Phillips head 000 screwdriver to remove the one 4.0mm screw on the side opposite of the USB port near the shutter button.
Open the flap at the top of the camera.
Use a Phillips head 000 screwdriver to remove the two 4.0mm screws inside.
Gently lift off the top panel with your hands.
Sehr klar und verständlich, ich konnte ohne Probleme folgen.
