Sony Alpha NEX-6 Lens Mount Replacement
  1. Sony Alpha NEX-6 Lens Mount Replacement, Finding the Release Button: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the camera with the lens facing up.
    • Find the lens release button - located along the side of the silver lens mount.
  2. Sony Alpha NEX-6 Lens Mount Replacement, Removing the Lens: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Alpha NEX-6 Lens Mount Replacement, Removing the Lens: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Press and hold the lens release button while rotating the lens counterclockwise.
    • Lift the lens when it is no longer attached to the camera.
    • To replace the lens, align the white dot on the lens with the white dot located on the silver lens mount. (See image two)
    • Insert the lens and rotate it clockwise until it is locked in place.
  3. Sony Alpha NEX-6 Lens Mount Replacement, Lens Mount: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • While dealing with this guide, do not touch the delicate image sensor (the center rectangle encircled by the lens mount).
    • After removing the lens, you will come into contact with the lens mount. Start by unscrewing the four 3.5 mm Phillips #00 screws.
    • The outer lens mount ring can now be removed.
  4. Sony Alpha NEX-6 Lens Mount Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Alpha NEX-6 Lens Mount Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Alpha NEX-6 Lens Mount Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pay attention to the positioning of the spacer rings for reassembly.
    • For the first (black) spacer ring, use the tweezers to gently pry the ring out of place.
    • Repeat this step for the second (silver) spacer ring.
    • The third image is what the camera should look like after all spacer rings are removed.
  5. Sony Alpha NEX-6 Lens Mount Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Alpha NEX-6 Lens Mount Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To remove the inner lens mount ring, remove the two silver 2.0 mm Phillips #00 screws. This will complete the removal of the lens mount.
Clayton Dale
crwdns2935283:001/20/15crwdne2935283:0
1,067 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 11-2, Blackwell Winter 2015 crwdns2935289:0USF Tampa, Team 11-2, Blackwell Winter 2015crwdne2935289:0
USFT-BLACKWELL-W15S11G2
crwdns2942667:0crwdne2942667:0 1,864
