This guide will show how to turn off the power for safety reasons, unlock the latch that conceals the battery compartment, and ejecting the battery for the Sony Alpha NEX-6
Turn the camera off by switching the power knob "OFF" text to the white selector dot.
Flip the camera upside-down and carefully place it on a flat surface.
With the lens facing outward, locate the battery compartment - indicated by a grooved latch.
Push the latch to the right to unlock the battery compartment. The door should flip upward.
With the compartment open, locate a blue tab shown with spudger
Press the tab to the side (to the left, or toward the camera wall). This will eject the camera battery.
Battery Stuck
Will not spring out. Any ideas?
Got it, battery damaged. Tapped on edge to remove battery
