Sony Alpha NEX-5N Camera Image Sensor Replacement
  1. Sony Alpha NEX-5N Camera Image Sensor Replacement, Motherboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Alpha NEX-5N Camera Image Sensor Replacement, Motherboard: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Alpha NEX-5N Camera Image Sensor Replacement, Motherboard: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the 3 silver 1.2 mm Phillips #000 screws from the bottom of the camera.
    • This does not include the two screws in the bottom of the LCD screen panel.
  2. Sony Alpha NEX-5N Camera Image Sensor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • On the bottom casing, locate the split along the tripod port.
    • Insert the prying tool into the split.
    • Pull the prying tool towards the LCD screen to begin separating the split.
    • Jiggling the prying tool may be necessary to open the split.
  3. Sony Alpha NEX-5N Camera Image Sensor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Hold the device with the lens facing you, and grasp the battery compartment.
    • Locate the split on the side of the battery compartment.
    • Locate the split and insert the prying tool.
  4. Sony Alpha NEX-5N Camera Image Sensor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the charging port.
    • Unscrew the silver 3.5 mm Phillips #0 screw next to the port.
  5. Sony Alpha NEX-5N Camera Image Sensor Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open the battery compartment.
    • Unscrew the 2 silver 3.5 mm Phillips #0 screws found at the inside bottom of the battery port.
  6. Sony Alpha NEX-5N Camera Image Sensor Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert prying tool in the split between the top panel (where you find the movie button) and the LCD screen.
    • Jiggle the prying tool and pull the tool away from the device.
    • The panel will fall off immediately.
  7. Sony Alpha NEX-5N Camera Image Sensor Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Alpha NEX-5N Camera Image Sensor Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the silver 3.5 mm Phillips #0 screw, visible on the left top edge when looking at the face of the device.
    • The dark gray panel that surrounds the shutter button and covers the battery compartment will be loose.
  8. Sony Alpha NEX-5N Camera Image Sensor Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the middle top of the device.
    • Unscrew 2 copper 1.2 mm Phillips #000 screws.
  9. Sony Alpha NEX-5N Camera Image Sensor Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To the right of where you unscrewed the copper screws, unscrew 4 black 1.2 mm Phillips #000 screws.
  10. Sony Alpha NEX-5N Camera Image Sensor Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Alpha NEX-5N Camera Image Sensor Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the tripod port.
    • Unscrew 2 black 1.2 mm Phillips #000 screws, one on each side of the tripod port.
    • Pull the section holding the LCD screen away from the device body.
  11. Sony Alpha NEX-5N Camera Image Sensor Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew 2 copper 1.2 mm Phillips #000 screws underneath the lanyard loop (near the control wheel).
  12. Sony Alpha NEX-5N Camera Image Sensor Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Alpha NEX-5N Camera Image Sensor Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Alpha NEX-5N Camera Image Sensor Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull off the metal back from the device body.
    • Locate a thin metal piece on top of the motherboard, and unscrew 4 silver 1.2 mm Phillips #000 screws in the corners of the metal piece.
    • Underneath. you will locate the motherboard.
    • The tripod piece will be loose. Take the piece from the device and set it off to the side.
  13. Sony Alpha NEX-5N Camera Image Sensor Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Alpha NEX-5N Camera Image Sensor Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The top and bottom of the device has ZIF ribbon cable connectors holding the motherboard in place.
    • Flip up the white retaining tabs, and utilize tweezer to, pull out the 2 thin ribbon cables, located on top of the motherboard.
    • Do not touch the ribbons with bare hands.
  14. Sony Alpha NEX-5N Camera Image Sensor Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Alpha NEX-5N Camera Image Sensor Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Alpha NEX-5N Camera Image Sensor Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate 3 thick ribbon cables on the bottom, and flip up the white retaining tabs. Pull out the remaining ribbon cables, utilizing tweezers.
  15. Sony Alpha NEX-5N Camera Image Sensor Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Alpha NEX-5N Camera Image Sensor Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the gray plastic camera piece surrounding the motherboard up.
    • Leave the long, thin ribbon cable that runs along the gray piece attached. It is not necessary to detach.
    • Lift up the motherboard to reveal one final thin ribbon cable connected to a white retaining tab underneath the motherboard.
    • Flip up the white retaining tab, and utilize tweezers to pull out the final thin ribbon cable.
  16. Sony Alpha NEX-5N Camera Image Sensor Replacement, Camera Image Sensor: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Alpha NEX-5N Camera Image Sensor Replacement, Camera Image Sensor: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew 3 black 2.25mm screws, utilizing the screwdriver head PH000, on the metal plate underneath the motherboard.
    • Utilizing a pair of tweezers, remove the metal plate from the device.
  17. Sony Alpha NEX-5N Camera Image Sensor Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Alpha NEX-5N Camera Image Sensor Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Detach the circuit board from the device.
  18. Sony Alpha NEX-5N Camera Image Sensor Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Alpha NEX-5N Camera Image Sensor Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Alpha NEX-5N Camera Image Sensor Replacement: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew 4 2.25mm Phillips #000 screws on the circuit board.
    • Remove the circuit board from the camera image sensor.
Tessa Reininger
crwdns2935283:009/28/15crwdne2935283:0
504 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team 1-4, Matresse Fall 2015 crwdns2935289:0Eastern Washington University, Team 1-4, Matresse Fall 2015crwdne2935289:0
EWU-MATRESSE-F15S1G4
crwdns2935297:013crwdne2935297:0
crwdns2936753:030crwdne2936753:0 82
crwdns2942667:0crwdne2942667:0 5,969
