Sony Alpha NEX-3N Sensor Replacement
  1. Sony Alpha NEX-3N Sensor Replacement, Getting Started: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Alpha NEX-3N Sensor Replacement, Getting Started: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove battery and card
  2. Sony Alpha NEX-3N Sensor Replacement, Back Case 1: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Alpha NEX-3N Sensor Replacement, Back Case 1: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Alpha NEX-3N Sensor Replacement, Back Case 1: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Right side, remove 1 M1.4x3.7 screw
    • Left side, remove 3 M1.4x3.7 screws
    • Bottom side, remove 5 M1.4x3.7 screws, including 2 in battery bay. 2 of them out of this photo, you can find them.
    • Do NOT touch screws on the bottom of LCD assembly.
  3. Sony Alpha NEX-3N Sensor Replacement, Back Case 2: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pop the flash.
    • In flash room, remove 1 (one) M1.4x3.8 black screw.
  4. Sony Alpha NEX-3N Sensor Replacement, Back Case 3: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Alpha NEX-3N Sensor Replacement, Back Case 3: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Alpha NEX-3N Sensor Replacement, Back Case 3: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove LCD hinge cover, by sliding to the left.
    • Remove back cover, actually just a plastic frame.
  5. Sony Alpha NEX-3N Sensor Replacement, LCD assembly: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Alpha NEX-3N Sensor Replacement, LCD assembly: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove 1 M1.4x2 screw
    • Remove another M1.4x2 screw, sorry for the angle.
  6. Sony Alpha NEX-3N Sensor Replacement, LCD Assembly: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Alpha NEX-3N Sensor Replacement, LCD Assembly: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Alpha NEX-3N Sensor Replacement, LCD Assembly: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • CAUTION. Sony makes world's MOST BRITTLE FPC!
    • Loosen LCD assemble with caution!
    • Release FPC cable, the connector is flip type.
  7. Sony Alpha NEX-3N Sensor Replacement, The LCD assembly: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The LCD assembly
  8. Sony Alpha NEX-3N Sensor Replacement, Dismantle the LCD Part: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Alpha NEX-3N Sensor Replacement, Dismantle the LCD Part: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Alpha NEX-3N Sensor Replacement, Dismantle the LCD Part: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • After unscrew 4pcs screw you will remove the steel black plate, then slowly pull the black frame there to see the ribbon stripe.
    • Slowly pull the very fragile ribbon lock which i marking with the blue boxes. around just 1mm to unlock the ribbon.. unlucky i broke mine..
  9. Sony Alpha NEX-3N Sensor Replacement, Dismantle the LCD Part: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Alpha NEX-3N Sensor Replacement, Dismantle the LCD Part: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Alpha NEX-3N Sensor Replacement, Dismantle the LCD Part: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • you can see the ribbon already pull out but be carefull with the others 2 ribbon when your try to pull out this ribbon.
    • the the circle marker that show others ribbon you need to be carefull. goodluck!
  10. Sony Alpha NEX-3N Sensor Replacement, Keypad: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Alpha NEX-3N Sensor Replacement, Keypad: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Alpha NEX-3N Sensor Replacement, Keypad: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the keypad.
    • Detach FPC
  11. Sony Alpha NEX-3N Sensor Replacement, Screws: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove 3 M1.4x3.6 black screws, 2 of them out of focus
  12. Sony Alpha NEX-3N Sensor Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Alpha NEX-3N Sensor Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the flash assembly backwards with caution.
    • Detach flash FPC by pulling it out of the socket.
    • High Voltage! Do NOT touch metal on FPC.
    • Then remove the flash assembly.
  13. Sony Alpha NEX-3N Sensor Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove that part whatever called, by sliding it backwards.
  14. Sony Alpha NEX-3N Sensor Replacement, Screws: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Alpha NEX-3N Sensor Replacement, Screws: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Alpha NEX-3N Sensor Replacement, Screws: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • 1 ST1.7x5
    • 2 ST1.7x5
    • 1 M1.4x3.6 black
  15. Sony Alpha NEX-3N Sensor Replacement, The Grip: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Alpha NEX-3N Sensor Replacement, The Grip: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove 2 ST1.7x5 screws from inside the battery bay. (one of them not shown, deeper inside) insert screw driver through a hole in the shielding cover.
    • Pop the grip off. From back, push to the right, then it flies forward.
  16. Sony Alpha NEX-3N Sensor Replacement, More Screws: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove 2 M1.4x2 black screws
  17. Sony Alpha NEX-3N Sensor Replacement, Pop the Shielding Cover: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Alpha NEX-3N Sensor Replacement, Pop the Shielding Cover: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • with caution and patient.
  18. Sony Alpha NEX-3N Sensor Replacement, One More Shield: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Alpha NEX-3N Sensor Replacement, One More Shield: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Alpha NEX-3N Sensor Replacement, One More Shield: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • 1 M1.4x3.6
  19. Sony Alpha NEX-3N Sensor Replacement, Detach 7000 FPCs: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Sensor power, flip
    • Sensor signal, flip
    • Shutter, pull
    • Lens contacts, pull. Did I mention that Sony makes world's most brittle FPC?
    • Whatever, pull
    • Whatever, pull
    • Shutter charger motor FPC, (backside, pull out)
  20. Sony Alpha NEX-3N Sensor Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the Mainboard up
    • Pull out one more FPC
    • Discharge then desolder 4 wires.
    • CAUTION! Possible high DC voltage >300V
  21. Sony Alpha NEX-3N Sensor Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift main board and plastic frame with flash capacitor.
  22. Sony Alpha NEX-3N Sensor Replacement, FPC cables: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Detach sensor Power (L)and Signal(R) FPC
  23. Sony Alpha NEX-3N Sensor Replacement, Screws: crwdns2935265:023crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove 3-4 ST1.7x5 screws
    • Remove 1 M1.4x5 screw
  24. Sony Alpha NEX-3N Sensor Replacement: crwdns2935265:024crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Alpha NEX-3N Sensor Replacement: crwdns2935265:024crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove 4 ST1.7x5 screws for the E-Mount
    • Remove mount metal ring
  25. Sony Alpha NEX-3N Sensor Replacement, E-Mount: crwdns2935265:025crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Alpha NEX-3N Sensor Replacement, E-Mount: crwdns2935265:025crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Alpha NEX-3N Sensor Replacement, E-Mount: crwdns2935265:025crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove mount plastic ring
    • remove mount spring ring
  26. Sony Alpha NEX-3N Sensor Replacement, Sensor + Shutter: crwdns2935265:026crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Sensor + Shutter assembly comes off
  27. Sony Alpha NEX-3N Sensor Replacement, Sensor Frame: crwdns2935265:027crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Separate sensor + shutter from another frame
  28. Sony Alpha NEX-3N Sensor Replacement, The Sensor: crwdns2935265:028crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Alpha NEX-3N Sensor Replacement, The Sensor: crwdns2935265:028crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Alpha NEX-3N Sensor Replacement, The Sensor: crwdns2935265:028crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove 3 ST1.7x5 screws
    • Remove sensor shield / heat sink. Sensor PCBA might sticks to the shield, just separate them.
Terrance
crwdns2935283:011/17/09crwdne2935283:0
6.698 crwdns2915208:0crwdne2915208:0
crwdns2935297:018crwdne2935297:0
crwdns2942667:0crwdne2942667:0 337
