            Remove battery and card
            Right side, remove 1 M1.4x3.7 screw
            Left side, remove 3 M1.4x3.7 screws
            Bottom side, remove 5 M1.4x3.7 screws, including 2 in battery bay. 2 of them out of this photo, you can find them.
            Pop the flash.
            In flash room, remove 1 (one) M1.4x3.8 black screw.
            Remove LCD hinge cover, by sliding to the left.
            Remove back cover, actually just a plastic frame.
            Remove 1 M1.4x2 screw
            Remove another M1.4x2 screw, sorry for the angle.
            Loosen LCD assemble with caution!
            Release FPC cable, the connector is flip type.
            After unscrew 4pcs screw you will remove the steel black plate, then slowly pull the black frame there to see the ribbon stripe.
            Slowly pull the very fragile ribbon lock which i marking with the blue boxes. around just 1mm to unlock the ribbon.. unlucky i broke mine..
            you can see the ribbon already pull out but be carefull with the others 2 ribbon when your try to pull out this ribbon.
            the the circle marker that show others ribbon you need to be carefull. goodluck!
            Lift the keypad.
            Detach FPC
            Remove 3 M1.4x3.6 black screws, 2 of them out of focus
            Slide the flash assembly backwards with caution.
            Detach flash FPC by pulling it out of the socket.
            Then remove the flash assembly.
            Remove that part whatever called, by sliding it backwards.
            1 ST1.7x5
            2 ST1.7x5
            1 M1.4x3.6 black
            Remove 2 ST1.7x5 screws from inside the battery bay. (one of them not shown, deeper inside) insert screw driver through a hole in the shielding cover.
            Pop the grip off. From back, push to the right, then it flies forward.
            Remove 2 M1.4x2 black screws
            with caution and patient.
            Sensor power, flip
            Sensor signal, flip
            Shutter, pull
            Lens contacts, pull. Did I mention that Sony makes world's most brittle FPC?
            Whatever, pull
            Whatever, pull
            Shutter charger motor FPC, (backside, pull out)
            Flip the Mainboard up
            Pull out one more FPC
            Discharge then desolder 4 wires.
            Lift main board and plastic frame with flash capacitor.
            Detach sensor Power (L)and Signal(R) FPC
            Remove 3-4 ST1.7x5 screws
            Remove 1 M1.4x5 screw
            Remove 4 ST1.7x5 screws for the E-Mount
            Remove mount metal ring
            Remove mount plastic ring
            remove mount spring ring
            Sensor + Shutter assembly comes off
            Separate sensor + shutter from another frame
            Remove 3 ST1.7x5 screws
            Remove sensor shield / heat sink. Sensor PCBA might sticks to the shield, just separate them.
            Remove sensor. the shutter assembly comes off.
            Separate Shutter assembly form the mount body.
            Remove 1 screw (from the "Front" side)
            Separate shutter curtain (Photo 3) from charging motor (not shown).
            Yes, replacing this little innocent part needs 3+ hours!
            After removing the mount+shutter+sensor, it appears.
My NEX-3N is not recognizing the lens. Is it possible to replace just the camera lens connector cable?
I guiess it's possible. I broke my lens cable and lost a bunch of contacts. Can't find a replace part. planning to copy that FPC and order some on jlcpcb, but way too lazy, and years passed now.
Terrance -
