Sony Alpha NEX-3N LCD assembly Replacement
Terrance
crwdns2944107:0crwdnd2944107:0Terrancecrwdnd2944107:0crwdnd2944107:0crwdnd2944107:02crwdnd2944107:0crwdne2944107:0
crwdns2944111:0N'w 13, 2024crwdne2944111:0
crwdns2931287:045crwdne2931287:0
crwdns2937801:0crwdne2937801:0
crwdns2944444:0crwdne2944444:0
crwdns2944105:0crwdne2944105:0
  1. Sony Alpha NEX-3N LCD assembly Replacement, Getting Started: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Alpha NEX-3N LCD assembly Replacement, Getting Started: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove battery and card
  2. Sony Alpha NEX-3N LCD assembly Replacement, Back Case 1: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Alpha NEX-3N LCD assembly Replacement, Back Case 1: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Alpha NEX-3N LCD assembly Replacement, Back Case 1: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Right side, remove 1 M1.4x3.7 screw
    • Left side, remove 3 M1.4x3.7 screws
    • Bottom side, remove 5 M1.4x3.7 screws, including 2 in battery bay. 2 of them out of this photo, you can find them.
    • Do NOT touch screws on the bottom of LCD assembly.
  3. Sony Alpha NEX-3N LCD assembly Replacement, Back Case 2: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pop the flash.
    • In flash room, remove 1 (one) M1.4x3.8 black screw.
  4. Sony Alpha NEX-3N LCD assembly Replacement, Back Case 3: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Alpha NEX-3N LCD assembly Replacement, Back Case 3: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Alpha NEX-3N LCD assembly Replacement, Back Case 3: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove LCD hinge cover, by sliding to the left.
    • Remove back cover, actually just a plastic frame.
  5. Sony Alpha NEX-3N LCD assembly Replacement, LCD assembly: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Alpha NEX-3N LCD assembly Replacement, LCD assembly: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove 1 M1.4x2 screw
    • Remove another M1.4x2 screw, sorry for the angle.
  6. Sony Alpha NEX-3N LCD assembly Replacement, LCD Assembly: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Alpha NEX-3N LCD assembly Replacement, LCD Assembly: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Alpha NEX-3N LCD assembly Replacement, LCD Assembly: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • CAUTION. Sony makes world's MOST BRITTLE FPC!
    • Loosen LCD assemble with caution!
    • Release FPC cable, the connector is flip type.
  7. Sony Alpha NEX-3N LCD assembly Replacement, The LCD assembly: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The LCD assembly
  8. Sony Alpha NEX-3N LCD assembly Replacement, Dismantle the LCD Part: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Alpha NEX-3N LCD assembly Replacement, Dismantle the LCD Part: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Alpha NEX-3N LCD assembly Replacement, Dismantle the LCD Part: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • After unscrew 4pcs screw you will remove the steel black plate, then slowly pull the black frame there to see the ribbon stripe.
    • Slowly pull the very fragile ribbon lock which i marking with the blue boxes. around just 1mm to unlock the ribbon.. unlucky i broke mine..
  9. Sony Alpha NEX-3N LCD assembly Replacement, Dismantle the LCD Part: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Alpha NEX-3N LCD assembly Replacement, Dismantle the LCD Part: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Alpha NEX-3N LCD assembly Replacement, Dismantle the LCD Part: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • you can see the ribbon already pull out but be carefull with the others 2 ribbon when your try to pull out this ribbon.
    • the the circle marker that show others ribbon you need to be carefull. goodluck!
Terrance
crwdns2935283:011/17/09crwdne2935283:0
6.671 crwdns2915208:0crwdne2915208:0
crwdns2935297:018crwdne2935297:0
Where can i get a lcd screen replacement?
Searched everywhere even AliExpress they do not sell the replacement lcd for this model
adfa dad - crwdns2934203:0crwdne2934203:0
No idea. I broke 2 FPC and lost some lens contact springs, got no where to buy, planning to replace the FPCs, but too busy these days .........
Terrance -
crwdns2936753:07crwdne2936753:0 22
crwdns2936753:030crwdne2936753:0 97
crwdns2942667:0crwdne2942667:0 1,902
