            Remove battery and card
            Right side, remove 1 M1.4x3.7 screw
            Left side, remove 3 M1.4x3.7 screws
            Bottom side, remove 5 M1.4x3.7 screws, including 2 in battery bay. 2 of them out of this photo, you can find them.
            Pop the flash.
            In flash room, remove 1 (one) M1.4x3.8 black screw.
            Remove LCD hinge cover, by sliding to the left.
            Remove back cover, actually just a plastic frame.
            Remove 1 M1.4x2 screw
            Remove another M1.4x2 screw, sorry for the angle.
            Loosen LCD assemble with caution!
            Release FPC cable, the connector is flip type.
            After unscrew 4pcs screw you will remove the steel black plate, then slowly pull the black frame there to see the ribbon stripe.
            Slowly pull the very fragile ribbon lock which i marking with the blue boxes. around just 1mm to unlock the ribbon.. unlucky i broke mine..
            you can see the ribbon already pull out but be carefull with the others 2 ribbon when your try to pull out this ribbon.
            the the circle marker that show others ribbon you need to be carefull. goodluck!
Where can i get a lcd screen replacement?
Searched everywhere even AliExpress they do not sell the replacement lcd for this model
No idea. I broke 2 FPC and lost some lens contact springs, got no where to buy, planning to replace the FPCs, but too busy these days .........
Terrance -
