Sony Alpha DSLR-A500 Shutter button Replacement
  1. Sony Alpha DSLR-A500 Shutter button Replacement, Remove attachments: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Alpha DSLR-A500 Shutter button Replacement, Remove attachments: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Alpha DSLR-A500 Shutter button Replacement, Remove attachments: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn off the camera. Uninstall camera lens, battery and SD card.
  2. Sony Alpha DSLR-A500 Shutter button Replacement, Remove rear panel: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Alpha DSLR-A500 Shutter button Replacement, Remove rear panel: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Alpha DSLR-A500 Shutter button Replacement, Remove rear panel: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the viewfinder cover.
    • Remove screws from below the cover and unscrew regulation wheel.
    • On the right side, remove one screw from "DC IN" panel and one below.
  3. Sony Alpha DSLR-A500 Shutter button Replacement, Remove rear panel, cont.: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Alpha DSLR-A500 Shutter button Replacement, Remove rear panel, cont.: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Alpha DSLR-A500 Shutter button Replacement, Remove rear panel, cont.: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • On the left side, remove one screw from "REMOTE" panel and one screw at the bottom of camera.
    • Pry off the side panel, remove marked screw.
  4. Sony Alpha DSLR-A500 Shutter button Replacement, Remove rear panel, cont.: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Alpha DSLR-A500 Shutter button Replacement, Remove rear panel, cont.: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Alpha DSLR-A500 Shutter button Replacement, Remove rear panel, cont.: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove four screws from the bottom.
    • Open the sd card flap and carefully tilt the back cover from that side, it should come off the camera.
    • Carefully disconnect the button and screen tapes from the motherboard. Pull them away from the ports using their wings, by the screen tape beforehand undermine the black locking mechanism.
  5. Sony Alpha DSLR-A500 Shutter button Replacement, Remove front cover: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Alpha DSLR-A500 Shutter button Replacement, Remove front cover: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Alpha DSLR-A500 Shutter button Replacement, Remove front cover: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove two screws from front and third one on the right.
    • Remove two screws from flash cover.
    • Remove one screw on the side.
  6. Sony Alpha DSLR-A500 Shutter button Replacement, Remove front cover, cont.: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Alpha DSLR-A500 Shutter button Replacement, Remove front cover, cont.: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove one screw at the bottom.
    • Pry off the cover from below so that it goes beyond the convex part of the inch thread hole.
  7. Sony Alpha DSLR-A500 Shutter button Replacement, Short-circuit the capacitor - DANGER: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Alpha DSLR-A500 Shutter button Replacement, Short-circuit the capacitor - DANGER: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Alpha DSLR-A500 Shutter button Replacement, Short-circuit the capacitor - DANGER: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • This step is done to minimize risk of accidental short-circuit which might be dangerous for both user and device.
    • Be very careful during this step! The capacitor can be charged up to 330 volts and cause a danger to life or health under unfortunate circumstances.
    • Short-circuit the contacts of the capacitor through a suitable load. I used 100k resistor for 5 seconds and later did second short-circuit with just a wire.
    • Remove white and red connectors.
  8. Sony Alpha DSLR-A500 Shutter button Replacement, Remove upper cover.: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Alpha DSLR-A500 Shutter button Replacement, Remove upper cover.: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Alpha DSLR-A500 Shutter button Replacement, Remove upper cover.: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew side screw and remove small panel. Below there is another screw to remove.
    • Unplug the tape of mode knob and the tape of viewfinder, remove two screws. Take off the cover.
  9. Sony Alpha DSLR-A500 Shutter button Replacement, Remove upper cover, cont.: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Alpha DSLR-A500 Shutter button Replacement, Remove upper cover, cont.: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • From the inside of the cover remove four screws.
    • Carefully remove the plate, do not deattach tapes.
  10. Sony Alpha DSLR-A500 Shutter button Replacement, Place the button: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Alpha DSLR-A500 Shutter button Replacement, Place the button: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • In replacement packed you should have the button, spring and tiny retaining ring.
    • Position button and spring on one side and put the retaining ring on button ring from the other side.
    • If you don't have the retaining ring, you can try to substitute it with small metal wire, for instance from the resistor.
grbrr
crwdns2935283:005/09/24crwdne2935283:0
241 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 55
crwdns2942667:0crwdne2942667:0 457
