Sony Alpha A350 Front Case Replacement
  1. Sony Alpha A350 Front Case Replacement, Front Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Alpha A350 Front Case Replacement, Front Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #00 Screwdriver, remove the four 5.5mm screws from the bottom of the camera.
    • Using a Phillips #00 Screwdriver, remove the one 4.3mm screw.
  2. Sony Alpha A350 Front Case Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Alpha A350 Front Case Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #00 screwdriver, remove one 3.6mm screw on the left side of the camera.
    • Open the remote / DC under the rubber flap to reveal a screw.
    • Using the Phillips #00 screwdriver, remove one 4.3mm screw.
  3. Sony Alpha A350 Front Case Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Alpha A350 Front Case Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open the flash on the top of the camera and remove two 4.3mm screws with a Phillips #00 screwdriver.
    • If the spring guard falls out during deconstruction, gently place the guard over the spring during construction.
    • To open the flash, simply press the button on the left side.
  4. Sony Alpha A350 Front Case Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Alpha A350 Front Case Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open the plastic SD card door.
    • Using Phillips #00 screwdriver, remove two 4.4 mm screws outside and two 4.4mm screws inside the door.
  5. Sony Alpha A350 Front Case Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Alpha A350 Front Case Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pull the outer front case from the camera.
    • It should fall apart easily if all screws are removed.
Danielle Trivett
crwdns2935283:011/04/19crwdne2935283:0
337 crwdns2915208:0crwdne2915208:0
IUPUI, Team S1-G6, Henning Fall 2019 crwdns2935289:0IUPUI, Team S1-G6, Henning Fall 2019crwdne2935289:0
IUPUI-HENNING-F19S1G6
crwdns2942667:0crwdne2942667:0 1,006
