Sony Alpha A350 : LCD Replacement
    1. Sony Alpha A350 : LCD Replacement, LCD: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Alpha A350 : LCD Replacement, LCD: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Lift up the screen.
      • Unscrew the two Phillips #000 screws on each side of the screen.
    2. Sony Alpha A350 : LCD Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Alpha A350 : LCD Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a plastic spudger to gently pry open the screen.
      • Continue to push and slide along the edge of the screen.
    3. Sony Alpha A350 : LCD Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Alpha A350 : LCD Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Lift up the glass screen protector from the LCD.
      • Lift the LCD to expose the ZIF connector.
    4. Sony Alpha A350 : LCD Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Alpha A350 : LCD Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Identify the ZIF (zero insertion force)connector (the black bar).
      • Flip the lever up and pull the connector out (Be sure not to yank the connector out to avoid damage).
      • Connect the new LCD and then flip the lever down.
crwdns2935229:08crwdne2935229:0
Sydney Duncan
crwdns2935283:010/10/16crwdne2935283:0
820 crwdns2915208:0crwdne2915208:0
CJLADIES crwdns2935289:0CJLADIEScrwdne2935289:0
Community
crwdns2947412:011crwdne2947412:0
This repair guide seems to show the replacement of a AUO Version of Sony Alpha A350 LCD Replacement. Could someone show how to replace a Sony version of a Sony Alpha A350 LCD Replacement. The two are different. Thanks
David - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
David,
if you're still looking to solve this : replacing the AUO version or the Sony version of the LCD is exactly the same. However, things get more complicated when you had a broken AUO and want to replace it with a SONY LCD, or vice versa, because the flex circuit (visible in step 4 ) is different between a AUO and SONY LCD. So without switching the flex circuit, you will not be able to switch the LCD from a Sony to a AUO or from a AUO to a Sony.
Am I making sense ? There are I think 4 versions in total of all flex circuits + components (according to the service manual) : 1 is unique for the AUO, 1 is for the Sony, and the last 1 is for both, but depending on components soldered onto it, it needs to be used for either AUO or Sony.
Switching to AUO makes sense, because prices for a Sony replacement LCD nowadays will cost you more then the complete camera.
AUO LCD's can be found for about 20 - 40 $ . If only you could get hold of the appropriate flex circuit.
Hope this helps.
Regards
lockinvar - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
years ago i had attempted to replace the screen with no knowledge and i broke the lever, my question to you is how do i fix it now?
Moriah Foster - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Moriah, I have the same issue. did you solve it ? I have a replacement screen but the ZIF plastic connector is broken. Did you find a way to fix it ?
Leopoldo Bolanos - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
This is BS. Thee is only one original screen, which is from Sony. AUO is an aftermarket screen, which isn’t suitable without a new flexcable. So if someone ask you which screen it is, if not replaced in the meantime, it’s always Sony.
R Dolphijn - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 35
crwdns2936753:030crwdne2936753:0 153
crwdns2942667:0crwdne2942667:0 11,237
