Sony Alpha A3000 shutter button Replacement
  1. Sony Alpha A3000 shutter button Replacement, Rear Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Alpha A3000 shutter button Replacement, Rear Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Alpha A3000 shutter button Replacement, Rear Case: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the seven highlighted screws shown here.
    • Screws are teeny tiny, don't lose them!
  2. Sony Alpha A3000 shutter button Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Alpha A3000 shutter button Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove this final screw from the memory card compartment.
    • Remove the chassis by pulling the back cover away from the camera.
    • Be careful not to damage any of the delicate ribbon cables when removing the chassis.
  3. Sony Alpha A3000 shutter button Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Alpha A3000 shutter button Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently but forcefully lift up on the parallel cable connecting the two halves of the camera.
  4. Sony Alpha A3000 shutter button Replacement, Motherboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Alpha A3000 shutter button Replacement, Motherboard: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After removing the backing from the camera. Remove the two final screws in the memory compartment area.
    • Detach the facing for the memory dock.
  5. Sony Alpha A3000 shutter button Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Alpha A3000 shutter button Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the eight screws securing the mount for the flash device.
  6. Sony Alpha A3000 shutter button Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Alpha A3000 shutter button Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the three remaining screws holding in the protective metal casing.
  7. Sony Alpha A3000 shutter button Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the metal casing.
  8. Sony Alpha A3000 shutter button Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove three screws holding down the motherboard .
  9. Sony Alpha A3000 shutter button Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Alpha A3000 shutter button Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Detach the nine serial cables connecting it to the camera body.
  10. Sony Alpha A3000 shutter button Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Finally remove the motherboard from the casing.
  11. Sony Alpha A3000 shutter button Replacement, ...: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • shutter button placement...
  12. Sony Alpha A3000 shutter button Replacement, Unscrew motherboard frame: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Alpha A3000 shutter button Replacement, Unscrew motherboard frame: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove two screws holding plastic/metal frame.
  13. Sony Alpha A3000 shutter button Replacement, Remove motherboard frame: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Alpha A3000 shutter button Replacement, Remove motherboard frame: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Holding the battery door gently lift the frame up .
  14. Sony Alpha A3000 shutter button Replacement, Capacitor module: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Alpha A3000 shutter button Replacement, Capacitor module: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull out the capacitor and move the capacitor board (flexible) to the left to clear the way for future steps.
  15. Sony Alpha A3000 shutter button Replacement, Remove buttons module: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Alpha A3000 shutter button Replacement, Remove buttons module: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Alpha A3000 shutter button Replacement, Remove buttons module: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove two screws mounting plastic buttons module.
    • Remove the module.
  16. Sony Alpha A3000 shutter button Replacement, Soldering!: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Alpha A3000 shutter button Replacement, Soldering!: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Alpha A3000 shutter button Replacement, Soldering!: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Replace the ALPS SKSDPCE010 microswitch. Look out for the correct allignment and orientation (first pin marked with a dot).
Andrzej Majchrzak
crwdns2935283:004/26/17crwdne2935283:0
131 crwdns2915208:0crwdne2915208:0
Excellent article, I would like to know what should be done to replace or repair the mode selector of the camera, (Dial mode) I appreciate this great contribution. Greetings.
Edgar Delgado - crwdns2934203:0crwdne2934203:0
Mode selector switch is visible on 2 photos of buttons module PCB. Look for a switch with blue knob on 2nd Photo of step 16. I dont know the serial number or replacement.
Andrzej Majchrzak - crwdns2934203:0crwdne2934203:0
Thank you so much for reply.
Edgar Delgado -
crwdns2936753:030crwdne2936753:0 49
crwdns2942667:0crwdne2942667:0 3,157
